Yes I saw what you guys have made and it is really cool. Not sure if I will implement it as I am happy with my current slider (which is also interactive, as in, I can scroll between notifications manually as well, and I can press it to show a different action/card).
Since custom header is gone… (i used it with vertical marquee)
How can i achieve this?
Can this been done with markdown? (i actually want one line of text showing states from multiple sensors)
It might be possible with a markdown card though I do not know, I think an HTML card could do this easier in your case.
I still hold on to my previous post where I just use button-cards in a swipe-card and the swipe-card automatically switches between the cards (a markdown could be used instead of the button-card though)
You can find examples of my code here (warning probably not easy to find)
as far as I know it the markdown card doesnt support the marquee, ive been experimenting with this same idea before.
But concerning the button, not sure what your issue is with the button, but you can style a button to not have it look like a button
it’s just a card disguised as a button, if you have it look like a button.
why dint you first try to make it, and then report back with you wishes to change it.
the options are endless… so seems most useful to begin and see what happens with the default settings
I do hope you edited this to have some entities of your own? undefined means these are not on your system…
since this is a regular Jinja template, you can test it in the developers template editor, to be correct and useful
So the button should be like “4 lampen en pc staan aan”
So without the button visual.
Button be wider…
And without the (25) System alerts text in front (gonna try this myself too )
Instead of horizontal scroll, can it be vertical?
edit: made it till this
You can see that the area where the text can scroll isnt as wide as the complete button, how do i fix this?
And how do i get rid of the button thing
@skank it is a very very old video from the beginning of this year. However the notifications haven’t changed since, so the video will represent a bit of what I did with it.
Note that I actually move them manually in the video (you can just scroll through them) but they also scroll automatically every 2 seconds or so (even after you manually scrolled through it, it will just continue automatically afterwards). Maybe this will give you an idea of what I did. I can simplify the code for you like below. You will have to do this for each ‘notification’ (without the swipe card) and put it in the list. To simplify things I will recommend using either lovelace_gen or decluttering-card to create a template so that you only need to fill a name and icon.
Hi cool
I got my binary sensors already.
I want to use templates indeed.
So i installed decluttering card
i need to create a yaml decluttering_templates in the root , right?
then enter the code as
decluttering_templates:
<template_name>
default: # This is optional
- <variable_name>: <variable_value>
card: # This is where you put your card config (it can be a card embedding other cards)
type: custom:my-super-card
I will send you a decluttering card code later on, not at home at the moment and I need to check how decluttering card works again since I haven’t used it for over a year. But it is very similar to the current template though.
