for example if I have certs in /volume1/fullchaim.pem I have to add at the docker run command this path -v /volume1:/volume1:ro?
This was the case for me i’m still fairly new to Docker but my understanding is this gives the container running HASS access to those files in this case certs outside of the container.
Hey,
so, this is how I have it here.
I have everything running in Docker with DuckDNS and LetsEncript. I think the trick is where you map the output of the certs and you connect on the HA side.
in my case, when I created the LetsEncript Docker Container running this:
sudo docker run -d --privileged --name=nginx -v /config/nginx:/config -e EMAIL=<emailaddress> -e URL=<domain> -p 443:443 -p 80:80 -e TZ=Europe/Madrid linuxserver/letsencrypt
NOTE: The image linuxserver/letsencrypt provides both Lets Encript and NGINX. That’s why I refer to it as NGINX in the Container name.
so in the Docker Host, in the path /config/nginx I have all the configuration and Cert keys.
then, when I create the docker container for HomeAssistant, I include the path from the LetsEncript Container as part of the HA one:
sudo docker run -d --name="home-assistant" -v /config/homeassistant/live:/config -v /etc/localtime:/etc/localtime:ro -v /config/nginx/etc/letsencrypt/:/etc/letsencrypt/ --net=host homeassistant/home-assistant
This way, I have mapped the Host path /config/nginx/etc/letsencrypt/ (output of the LetsEncript Container) in the Container path /etc/letsencrypt/ so it’s looking perfectly aligned with the instructions in the web (https://home-assistant.io/blog/2015/12/13/setup-encryption-using-lets-encrypt/)
Now, in the HomeAssistant Configuration file I have the following:
http:
api_password: !secret http.api_password
ssl_certificate: /etc/letsencrypt/live/<domain>/fullchain.pem
ssl_key: /etc/letsencrypt/live/<domain>/privkey.pem
hope this helps.
Recommend looking at nginx(running in docker) and reverse proxy.
In the long run it reduces required open ports in network
For me only nginx docker server has cert installed.
Nginx forwards from Synology (docker) to raspberry pi running HA along with several other docker apps all secured by Cert installed on nginx server
I’m been hearing more and more about nginx lately. I’m going to have a look at setting it up. Have you found any negatives to using nginx as apposed to a open port? Thanks for the suggestion @tmjpugh
No negatives. much simpler
I use certbot but could not get this and nginx to run together in single container. I created a separate Certbot docker and change nginx config when I manually update certificates. will deal with automating this later
Docker Create command for NGINX on synology
docker create -p exthttpportt:8080 -p exthttpsport:443 -v synologywebexposedfolder:/var/www -v /etc/localtime:/etc/localtime:ro -v synologynginxconfigfolder:/etc/nginx --name=nginx nginx:latest
drop the config file below into the nginx config folder specified above
point any port to the docker container and it will work.
Be aware that port in config is the container port not host port. So you can forward WAN port 8081 to Host port 8443 and have that point to container port 80. 80 would be used in NGINX config
NGINX CONFIG
just to give you a jumpstart if needed
I’m not a networking guru so verify below but it should work
I have subdomains but you could also use different domain name or other method. NGINX looks for requested server name and port in a specified order to determine request routing
user root; #probably don't want to run as root
# EVENTS #
events {
worker_connections 4096;
# HTTP #
http {
# WWW @ lOCALHOST #
server {
listen 8080 default_server;
server_name yoursite.com;
#access_log logs/big.server.access.log main;
location / {
root /var/www;
# HTTP HASS EXAMPLE #
server {
listen 8080;
server_name subdomain.yoursite.com;
location / {
proxy_set_header X-Forwarded-Server $host;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_pass http://192.168.0.1:8123; #http request to subdomain can forward to separate internal server
# HTTPS SERVER #
# @ WEBROOT #
server {
listen 443 ssl;
ssl on;
ssl_certificate /etc/locationofyourcert//fullchain.pem;
ssl_certificate_key /etc/locationofyourcert/privkey.pem;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
ssl_ciphers HIGH:!aNULL:!MD5;
location / {
root /var/www;
# HTTPS HASS EXAMPLE #
server {
listen 443 ssl;
ssl on;
ssl_certificate /etc/locationofyourcert/fullchain.pem;
location / {
proxy_set_header Host $host;
proxy_redirect http:// https://;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "upgrade";
proxy_buffering off;
proxy_ssl_verify off;
# FILE END #
Hello Luis,
Sorry to bother you with this old post,
I am building my network in a new build and have came across pFSence firewall/Router.
Which router are you using? What you suggest for a normal size family network from their product range.
Anil
@tmjpugh thank you for sharing this. I was stuck and can now see HA. Could you advise how to add additional proxy_pass.
So for instance I want to add the configurator to the panel frame, so It needs a pass.
http://192.168.0.1:3218
thank you
I now drop all http requests and accept only https pretty much.
I will post updated example later tonight
not a complete config but I think it shows what you were looking for
I am NO nginx expert so Please Read NGINX docs and understand(maybe improve) the items below. I didnt just copy paste but I do know I should reread docs myself and look over my below config for security errors
http {
server {
return 404;
# HTTP UPSTREAM SERVERS #
upstream homeassistant_backend {
server 192.60.27.12:8123;
server 192.60.27.13:8123;
upstream unifi_8443_backend {
#ip_hash;
#least_conn;
server 192.60.27.12:8443;
server 192.60.27.13:8443;
# HTTP HASS #
server {
listen 80;
server_name myserver.com;
location / {
return 444;
# HTTPS SERVER #
# HTTPS HASS #
server {
listen 443 ssl;
access_log /var/log/nginx/access/hass.log;
#error_log /var/log/nginx/error/hass.log;
ssl on;
ssl_certificate /etc/letsencrypt/live/myserver.com/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/myserver.com/privkey.pem;
ssl_ciphers "EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH:!aNULL:!eNULL:!EXPORT:!DES:!MD5:!PSK:!RC4";
ssl_prefer_server_ciphers on;
ssl_session_cache shared:SSL:10m;
location / {
proxy_pass http://homeassistant_backend;
#proxy_redirect http:// https://;
proxy_set_header Connection default_upgrade;
# HTTPS UNIFI #
server {
listen 443 ssl;
server_name unifi.myserver.com;
access_log /var/log/nginx/access/unifi.log;
#error_log /var/log/nginx/error/unifi.log;
ssl on;
ssl_trusted_certificate /etc/nginx/.ssl/unifi.pem;
location / {
proxy_pass https://unifi_8443_backend;
# FILE END #
@tmjpugh thank you very much. I’ve copied it and I can see the HA instance, however, I cant access the second instance (unifi in your case). couple of questions. in your upstream section you pair 2 ips per server?
and in the unifi seciton you use ssl_trusted_certificate /etc/nginx/.ssl/unifi.pem;
is this to replace a wild card cert? thank you
upstream 2 IP point to server with dual nic. This is round robin load balance.
http://nginx.org/en/docs/http/ngx_http_upstream_module.html
ssl_trusted_certificate is for unifi server self-signed cert. if you point to ssl server you must trust the certificate it uses
http://nginx.org/en/docs/http/ngx_http_ssl_module.html
