I’m trying to make a list of sensors not updated for some time.
In first place I’ve tried to select all the sensors updated before now()
without problem with the next code:
{% set sensor_lu_list = states.sensor | selectattr('last_updated', 'lessthan', now()) | map(attribute='last_updated') | list %}
{{ sensor_lu_list }}
I get something like:
[datetime.datetime(2021, 10, 14, 7, 38, 36, 891149, tzinfo=datetime.timezone.utc), datetime.datetime(2021, 10, 13, 13, 4, 58, 709781, tzinfo=datetime.timezone.utc), datetime.datetime(2021, 10, 14, 7, 57, 22, 382337, tzinfo=datetime.timezone.utc), datetime.datetime(2021, 10, 13, 13, 1, 28, 374336, tzinfo=datetime.timezone.utc),
BTW, if I print one of the list elements, the format is converted to UTC:
{{ sensor_lu_list[0] }}
and the output is:
2021-10-14 07:38:36.891149+00:00
Now I have two problems:
In first place, I need to map the entity_id
attribute instead of last_updated
, but if I try this in the template depeveloper tools I have no output (it doesn’t work):
{% set sensor_ids_list = states.sensor | selectattr('last_updated', 'lessthan', now()) | map(attribute='entity_id') | list %}
{{ sensor_ids_list }}
In second place, I don’t get how to change now() to now() - x hours. I’ve tried this without success:
{% set sensor_lu_list = states.sensor | selectattr('last_updated', 'lessthan', ((as_timestamp(now())-4*3600)|timestamp_custom ('%Y-%m-%d %H:%M:%S.%f%z')) | map(attribute='last_updated') | list %}
Any help or hint will be welcome.
TIA.
