Self Hosted Push Notifications with Gotify
Hi Juan,
I used your configuration. But whenever I am trying to send a notification by adding a priority the gotify server returns HTTP 400. I figured out that this is because HA sends the priority value as a string instead of an integer.
This is my configuration
  • name: gotify
    platform: rest
    resource: https://myserver/message
    method: POST_JSON
    headers:
    X-Gotify-Key: !secret gotify_api_token
    message_param_name: message
    title_param_name: title
    target_param_name: priority
This is how it looks in the network trace
grafik
If I am using the example where the priority is set with a fixed value in the notify config it says “Number value” instead. So I guess HA puts the priority value in double quotes when it sends it to the gotify server.
From HA developer tools - services I am putting the value “10” (without the double quotes) into the target field
Do you have an idea what I might be doing wrong?
Best Regards
Matthias
