Send entity State to Notification using HA Automations
I need to make an automation that sends the alarm panel status on change detected to a notification. the problem i am having how to put the status in the message part of the notification.
i.e. how I can put the entity status into the notification message? I managed to do in in Node-Red by sending the msg.payload but I am having problems with the Automation
well, for one, i’m assuming your googling around for the word ‘status’ and that’s your problem. Status is not a thing in home assistant. You need to figure out the lingo so you know what to look for and what to ask.
hi petro … I think it should be State not Status.
I tried using the is_state but till now I did not manage.
what I need to send the state shown here:
well, post your current automation and I can help you tailor it. It’s going to require templates.
thanks for helping out … unfortunately I never used templates in automations. This is what I have working right now:
- id: '1574523322809'
  alias: Alarm Panel Change send Notification
  description: Alarm Panel Change send Notification
  - entity_id: alarm_control_panel.alarm_panel
    platform: state
  condition: []
  - data:
      message: Alarm Status Changed
    service: notify.hassio_notifier_s7
to get the state,
change your action to:
  - data_template:
      message: "Alarm status changed to {{ trigger.to_state.state }}"
thanks again!
Tried it … but not working. In the logfile I got:
2019-11-23 19:23:41 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.alarm_panel_change_send_notification. Error rendering template for call_service at pos 1: UndefinedError: ‘trigger’ is undefined
What does trigger do?
See the docs. It’ll work, as long as you don’t try to trigger it manually.
managed to make it work! thanks for your help!
The GUI does not let you use data_template, had to do it from the yaml file.
@petro
I am trying to make something simular, but i can not get it to work. Can you have a look at it maybe:
alias: AllergyInfo Air Quality Today
description: Luchtkwaliteit Vandaag Notification
  - platform: time
    at: '13:00'
  - alias: Test
    condition: or
    conditions:
      - condition: state
        entity_id: sensor.air_quality_today_names
        state: Slecht
      - condition: state
        state: Ongezond
      - condition: state
        state: Zeer Ongezond
      - condition: state
        state: Gevraarlijk
  - data_template:
      message: "Alarm status changed to {{ sensor.air_quality_today.state }}"
      title: TEST
    service: notify.rick_android
It does not send any notification
All you had to do was copy the code without changing anything aside from the notification service
EDIT: NEvermind, your trigger is a time trigger. Change the code to grab the state using the state method. i.e. states('your_entity_id_in_single_quotes')
see my edit
Thank you! it works :smiley:
  - data_template:
      message: '{{ states(''sensor.acc_air_today_info'') }}'
      title: >-
        Allery Info - Luchtkwaliteit is {{
        states('sensor.air_quality_today_names') }} Vandaag
