Thankyou for the plugin, it works an absolute treat. I’ve tested incoming and outbound, just what I wanted. This was my last stumbling block to move away from another package Great work, thankyou
Two questions:
Is there a mode where the inbound SMS event is triggered immediately via the inbound sms or is this done via polling the modem ?
If its polling only, can we shorten the polling time ?
Logger: homeassistant.components.sms.gateway
Source: components/sms/gateway.py:167
Integration: SMS notifications via GSM-modem ([documentation](https://www.home-assistant.io/integrations/sms), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+sms%22))
First occurred: 8:04:29 AM (1 occurrences)
Last logged: 8:04:29 AM
Failed to initialize, error ERR_NOTSUPPORTED
Tried to add modem again with no luck with /dev/ttyUSB1 or /dev/ttyUSB2
I have the same problem. It was working before but after the update did not work anymore. I tried to remove the integration and configure it again but I get always the same message “Failed to connect”
It is exactly the same for me as it writes Birillo71. Update 2021.7.2 doesn’t change anything for the better. After restoring the snapshot to core-2021.6.6, sending SMS works fine again. With the 2021.7.x version, I removed the integration and added it again, but I always received a message during the configuration “Failed to connect”.
Hi, is there any news about the fix to the SMS functionality? I tried also version 2021.7.4 but this is still not working. I reverted again to version 2021.6.6. Apparently this is the latest version on which SMS are working
On HA 2021.8.6 (and I think even since the patch introduced in 8.3) sending of sms works fine however receiving leads to restart of HA with no error showing up in the log.
2021-08-15 12:25:09 INFO (MainThread) [homeassistant.setup] Setting up sms
2021-08-15 12:25:09 INFO (MainThread) [homeassistant.setup] Setup of domain sms took 0.0 seconds
2021-08-15 12:25:15 WARNING (MainThread) [homeassistant.components.sms.gateway] GSM error, your phone does not support incoming SMS notifications!
2021-08-15 12:25:15 INFO (MainThread) [homeassistant.components.notify] Setting up notify.sms
2021-08-15 12:25:15 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.sms
2021-08-15 12:25:22 INFO (MainThread) [homeassistant.components.automation.read_sms] Initialized trigger read-sms
