Send SMS with USB GSM modem when alarm triggered
My approach is:
1. Variant
  • gsm modem on linux (in my case host of hassio docker)
  • install gammu-smsd
  • configure stored data in sql database (install/configuration of sql server needed)
  • configure gammu-smsd to call script after received sms (curl command to call homeassistant webhook with json data from sms)
#!/bin/sh
from=$SMS_1_NUMBER
message=$SMS_1_TEXT
curl --request POST \
     --url 'https://homeassistanturl/api/webhook/incomingsms' \
     --header 'content-type: application/json' \
     --data "$( jq -nc --arg dela "$from" --arg mesaj "$message" '{"from": $dela, "smsmesaj":  $mesaj }' )"
  • generate ssh key in /homeassistant/config (to be persistent) and copy ssh keys to sistem host.
  • issue rest_command from home assistant
trimitesms: ssh -i /config/ssh/id_rsa -o StrictHostKeyChecking=no user@iphost 'gammu-smsd-inject TEXT {{ numarsms }} -text "{{ textsms }}"'
  • make sql sensor to read recieved and send sms data from gammu
  • make a custom lovelace card to display all data
gsm-lovelace-card
2. Variant (easy one)
esphome:
  platform: ESP32
  board: esp-wrover-kit
wifi:
  ssid: ''
  password: ''
logger:
  level: debug
  # baud_rate: 0
ota:
api:
  services:
  - service: send_sms
    variables:
      recipient: string
      message: string
    then:
    - sim800l.send_sms:
        recipient: !lambda 'return recipient;'
        message: !lambda 'return message;'
uart:
  baud_rate: 9600
  tx_pin: 27
  rx_pin: 26
switch:
  - platform: gpio
    pin: 4
    restore_mode: ALWAYS_OFF
  - platform: gpio
    pin: 5
    restore_mode: ALWAYS_ON
  - platform: gpio
    pin: 23
sim800l:
  on_sms_received:
    - lambda: |-
        id(sms_sender).publish_state(sender);
        id(sms_message).publish_state(message);
    - logger.log:
        format: "Received '%s' from %s"
        args: [ 'message.c_str()', 'sender.c_str()' ]
text_sensor:
I use both variants to send critical alerts about my sistem. (Even if i have no power/internet).
I am planning on using python gammu natively as a notify component in home-assistant.
The actual code to send a SMS is very simple:
import gammu
sm = gammu.StateMachine()
sm.ReadConfig()
sm.Init()
message = {
    'Text': 'python-gammu testing message',
    'SMSC': {'Location': 1},
    'Number': '+420800123465',
sm.SendSMS(message)
I like that this is a simpler setup.
Yes, for sending you can use this. But i don’t have found a solution for receiving.
I want to work both way. To send and receive sms :slight_smile:
Gammu also have a nice python interface to receive SMS notifications, it will be relate easy to add once I have an integration that works for sending.
Thank you so much for the esphome code …
been having trouble with this for a while …
worked like a charm on the 1st go …
thank you also @reliable
I am happy to announce that with version 0.105.0, SMS notifications (via Gammu) are officially supported.
Here is more info
Hi Thats Really Great!
I’ve first question about it.
Ubuntu 18.04 server/docker, Hassio 105.1, Gammu installed, sending sms from putty without any error.
Configuration file:
 sms:
   device: /dev/ttyUSB3
 notify:
   - platform: sms
     recipient: +NNNNNN
   - platform: sms
     recipient: +NNNNNN
Im getting:
Configuration invalidCHECK CONFIG
Invalid config for [sms]: No device at /dev/ttyUSB3 found for dictionary value @ data['sms']['device']. Got '/dev/ttyUSB3'. (See /config/configuration.yaml, line 210).
Go to your ssh session and type:
ls -l /dev/*tty*
Do you see your modem? Then make sure you are sharing that serial device with the container. (I am not an expert in docker but there is a way to do this)
If this work please share the solution to update the documentation :slight_smile:
SOLVED
I needed libgammu-dev installed at the base system level.
Leaving my post below for reference…
Thanks for your work on this @Oscar_Calvo.
I’m looking forward to replacing my existing sms integration call gammu through a parameterised shell_command.
Unfortunately I’m unable to get python-gammu installed on my Python3.7 venv running on Ubuntu 18.04 when the sms integration is configured.
Running the install command under the homeassistant user within the activated venv gives me some clues as to what is going on:
(homeassistant) homeassistant@moxon:~/.homeassistant$ python3.7 -m pip install python-gammu
Collecting python-gammu
  Using cached python-gammu-2.12.tar.gz (135 kB)
    ERROR: Command errored out with exit status 100:
     command: /srv/homeassistant/bin/python3.7 -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-ea2vl0z7/python-gammu/setup.py'"'"'; __file__='"'"'/tmp/pip-install-ea2vl0z7/python-gammu/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-install-ea2vl0z7/python-gammu/pip-egg-info
         cwd: /tmp/pip-install-ea2vl0z7/python-gammu/
    Complete output (9 lines):
    Package gammu was not found in the pkg-config search path.
    Perhaps you should add the directory containing `gammu.pc'
    to the PKG_CONFIG_PATH environment variable
    No package 'gammu' found
    Package gammu-smsd was not found in the pkg-config search path.
    Perhaps you should add the directory containing `gammu-smsd.pc'
    No package 'gammu-smsd' found
    Can not find supported Gammu version using pkg-config!
ERROR: Command errored out with exit status 100: python setup.py egg_info Check the logs for full command output.
gammu-smsd is installed (with sudo apt install gammu-smsd) but I’m guessing that the above is related to permissions?
I’m rather out of my depth at this point so would appreciate any pointers you could provide.
hi,
I’m a noob with home assistant, and I’m coming from domoticz. I installed hass.io, and I’m trying to install gammu (I write a python script to control domoticz via SMS : start alarm, stop alarm, send SMS when something happened etc… and I need to do something like this). But I don’t understand what is my problem, and what I need to do to install this addon. Only modification in configuration.yaml? must I install some script? must I install gammu (apk)?
If somebody can help, it will be really nice :slight_smile:
Thanks a lot
my conf: hassos 3.9 on rasberry pi 3B home assistant 0.105.2
In theory only your yaml configuration file.
What model and brand is your gsm modem?
Huawei E3531 Surf Stick (HSPA +, USB, HSUPA, Edge/GPRS)
It works nice with domoticz and gammu
I will try to see logs via ssh. (hassio don’t start when I add config in configuration.yaml)
Install the sshd add on.
Type lsusb
You may need to configure run usb mode switch manually
Follow the instructions for raspberry pi on https://www.home-assistant.io/integrations/sms
Ok thanks a lot Oscar :slight_smile: I will do that as soon as possible, and I post the result.
When running lsusb you need to obtain the brand ID for Huawei and the model ID and create a config file for a USB config stick and reboot Hassos.
bus 001 device 005: ID 12d1:15ca.
for huawei stick.
I create the file in udev like for raspberry 4? No I think not…
“create a config file for a USB config” how I do that…
NOTE ABOUT Huawei and certain devices like RPI
You need to create udev rule in a configuration USB stick for the some Huawei sticks to be recognized.
Run lsusb, its output looks like this:
bus 000 device 001: ID 1FFF:342a
bus 001 device 005: ID 12d1:15ca   <-------- Huawei is usally 12d1
bus 000 device 002: ID 2354:5352
bus 000 device 002: ID 1232:15ca
Identify the brand for your GSM modem, copy the brand_Id and product_id (In this case brand_id = 12d1 and product_Id = 15ca)
Set this content in file udev\10-gsm-modem.rules in the configuration USB:
(Replace brand_Id and product_id for the numbers reported by lsusb)
ACTION=="add" \
, ATTRS{idVendor}=="brand_Id" \
, ATTRS{idProduct}=="product_Id" \
, RUN+="/sbin/usb_modeswitch -X -v brand_Id -p product_Id"
Here is a sample configuration file:
ACTION=="add" \
, ATTRS{idVendor}=="12d1" \
, ATTRS{idProduct}=="15ca" \
, RUN+="/sbin/usb_modeswitch -X -v 12d1 -p 15ca"
Plug the USB stick, reboot the device, run lsusb again.
The resulting product id now should be different and the brand id should be the same.
And ls -l /dev/*USB* should now report your device.
If the device is still not recognized, remove the parameter -X from the usb_modesiwtch command and reboot again.
DID IT !! thanks a lot Oscar, and sorry to be such a noob… I begin home assistant with gammu
Hi, trying to setup the new integration, I get this error :
{'Text': 'No SMSC number given. Provide it manually or use the one configured on the phone.', 'Where': 'SendSMS', 'Code': 31}
This is because the PIN is missing I think, is it possible to add it in the YAML config ?
Pin is not supported at this time, but adding support for it should not be hard.
