Many thanks @Mahko_Mahko
I just realized indeed this morning that we shall use the quoted lambda in a different filter node and not within the main lambda.
I already tested this, but you were quicker. The below works perfectly! Very nice, thank you again!
text_sensor:
update_interval: 1s
icon: mdi:progress-clock
filters:
- lambda: |-
static std::string last;
if (x == last)
return {};
last = x;
return x;
lambda: !lambda |-
auto ctrl = id(sprinkler_ctrl);
auto active = ctrl->active_valve();
if (!active.has_value()) {
return std::string("--");
auto time_remaining = ctrl->time_remaining_active_valve();
if (!time_remaining.has_value()) {
return std::string("00");
int seconds = round(id(sprinkler_ctrl).time_remaining_active_valve().value_or(0));
int days = seconds / (24 * 3600);
seconds = seconds % (24 * 3600);
int hours = seconds / 3600;
seconds = seconds % 3600;
int minutes = seconds / 60;
seconds = seconds % 60;
return {
((days ? String(days) + "d " : "") +
(hours ? String(hours) + "h " : "") +
(minutes ? String(minutes) + "m " : "") +
(String(seconds) + "s")
).c_str()};
