Okay, so here’s my configuration.
It’s not perfect as I said because the Thermostat Card assumes the climate device is turned on by selecting a mode and that also “off” is one of those modes. The Thermostat Card doesn’t support a separate on/off toggle like my air conditioner has. So I had to workaround that with automations. The MQTT Climate component also does not have a separate template mode for receiving the MQTT commands, it only has one for sending. So I had to use automations to get around that too.
Also, the internal temperature sensor isn’t exposed in this config so it will only show the temp from the climate device.
Anyway, Here we go.
# configuration.yaml
climate:
- platform: mqtt
modes:
- "auto"
- "cool"
- "heat"
- "off"
fan_modes:
- auto
- high
- mid
- low
power_command_topic: "/aircon/<mac_address>/power/set"
power_state_topic: "/aircon/<mac_address>/power/value"
mode_command_topic: "temp/climate/hvac_mode_bedroom"
mode_state_topic: "/aircon/<mac_address>/mode/value"
mode_state_template: >-
{% set values = { 'AUTO':'auto', 'HEATING':'heat', 'COOLING':'cool', 'OFF':'off' } %}
{{ values[value] if value in values.keys() else 'OFF' }}
temperature_command_topic: "/aircon/<mac_address>/temp/set"
temperature_state_topic: "/aircon/<mac_address>/temp/value"
fan_mode_command_topic: "/aircon/<mac_address>/fanspeed/set"
fan_mode_state_topic: "/aircon/<mac_address>/fanspeed/set"
min_temp: 16
max_temp: 32
temp_step: 0.5
precision: 0.5
# Automations.yaml
- alias: hvac-mode-controller-bedroom
platform: mqtt
topic: temp/climate/hvac_mode_bedroom
condition: or
conditions:
- condition: template
value_template: "{{ trigger.payload == 'auto' }}"
value_template: "{{ trigger.payload == 'heat' }}"
value_template: "{{ trigger.payload == 'cool' }}"
- service: mqtt.publish
data_template:
topic: /aircon/<mac_address>/power/set
payload: 'ON'
data_template:
topic: /aircon/<mac_address>/mode/set
payload: >
{% set values = { "auto":"AUTO", "heat":"HEATING", "cool":"COOLING", "off":"OFF" } %}
{{ values[trigger.payload] if trigger.payload in values.keys() else "off" }}
- alias: hvac-mode-controller-bedroom-power
platform: mqtt
payload: 'off'
data_template:
payload: 'OFF'
- service: climate.set_hvac_mode
entity_id: climate.bedroom
hvac_mode: 'off'
Here’s the look from the UI.
You’ll notice in the automations above, When selecting the mode, I have to send the power on command first, this is because my AC unit will not turn on just by switching modes.
Hope this makes sense to/helps someone.
