Lights, Camera, Action! Get ready to grab the popcorn because it’s movie time with a touch of cinematic magic! ![]()
New Feature
- Automation Link - Time Delay: When you stop the media player, you can use the Lights ON at End option to set the lights to a comfortable brightness… say, 50%. After the Time Delay has passed, the automation link turns OFF, handing control back to your primary light automation (Sensor Light Blueprint), which might restore the lights to full brightness (e.g., 100%). This gradual transition gives your eyes time to adjust, creating a smoother shift from movie mode back to your regular lighting and enhancing the overall user experience.
Bugs Fixed
- Fixed bugs in bypass.
- Fixed light flicker in end lights
Maintenance
- From time to time, Home Assistant updates their YAML standards and coding practices. To align with their roadmap, we’ve updated the code accordingly. We will continue to apply these updates across all our blueprints as they are revised.
If you like this blueprint? Consider hitting the
button in the top post ![]()
If you like my blueprints, and would like to show your support or just say thank you? Click Here ![]()
Enjoy
Blacky ![]()
