Tsar
(Christian)
April 2, 2022, 4:46pm
1
I copied this of another topic, but it’s not working
I’m sure it must be something stupid, but…
- platform: sql
db_url: mysql://homeassistant:9SxxxxxxWt@core-mariadb/homeassistant?charset=utf8
queries:
- name: DB size
query: "SELECT table_schema AS 'db_name', ROUND(SUM( data_length + index_length ) / 1024 / 1024, 2) AS 'size_mb' FROM information_schema.TABLES WHERE table_schema='hass_db'"
column: "size_mb"
unit_of_measurement: MB
But after restart of HA I get nothing :
Schouldn’t ‘hass_db’ be ‘homeassistant’ in your case?
There are no stupid questions. You just overlooked it.
and someone else with a fresh look doesn’t.
Nope Glad you asked so now I can build upon your work Thanks Tsar & Janneman
For me this worked:
Settings → Devices → Add Integration → SQL
Now fill in all the fields there like this:
And the Sensor appears… just for future reference I thought give the steps an update
Wxll
this helped a lot! thank you!
Hi ho communinity,
I don’t know what to change here. The database is reachable (it worked as the recorder) but the query seems to be wrong ;-(
User+pw will be exchanged by real secrets
Here is the code:
### MARIA DB SIZE ##############################################################
- platform: sql
db_url: mysql://user:[email protected] :3307/homeassistant?charset=utf8mb4;ssl=true
queries:
- name: MariaDB size
query: "SELECT table_schema AS 'homeassistant', ROUND(SUM( data_length + index_length ) / 1024 / 1024, 2) AS 'size_mb' FROM information_schema.TABLES WHERE table_schema='homeassistant'"
column: "value"
Thanks in advance!
//Erik
Read the documentation : SQL - Home Assistant
Replace size_mb by value.
xbmcnut
(xbmcnut)
April 30, 2023, 1:32am
11
Been using HA for 7yrs and didn’t even know that was a thing! Thank you.
Hmmm,
I put this code to confi…yaml but the sensor is not being created?
I’m lost ;-(
- platform: sql
queries:
query: "SELECT table_schema AS 'homeassistant', ROUND(SUM( data_length + index_length ) / 1024 / 1024, 2) AS 'value' FROM information_schema.TABLES WHERE table_schema='homeassistant'"
column: 'value'
[/quote]
Does anybody have a better idea?
Best regards
Erik
Does this work ?
- platform: sql
queries:
query: "SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="homeassistant" GROUP BY table_schema;"
column: 'value'
I have been trying recently and although the console works from phpmyadmin, the sensor does not appear in home assistant.
recorder:
db_url: mysql://user_hadb:[email protected] /db_ha?charset=utf8mb4
purge_keep_days: 365
- platform: sql
queries:
query: 'SELECT table_schema "database", Round(Sum(data_length + index_length) / 1048576, 2) "value" FROM information_schema.tables WHERE table_schema="db_ha" GROUP BY table_schema;'
column: 'value'
X4V1
(X4 V1)
June 20, 2023, 5:31pm
16
For the next ones who could pass here. I struggled with that too.
There are my findings:
Nesting the config in the sensor array did not worked for me. Putting the config outside of sensor worked.
Example:
NOT WORKING:
- platform: sql
db_url: !secret maria_db_url
scan_interval: 3600
queries:
- name: MariaDB DB Size
query: 'SELECT table_schema "database", Round(Sum(data_length + index_length) / POWER(1024,2), 1) "value" FROM information_schema.tables WHERE table_schema="ha-record" GROUP BY table_schema;'
column: "value"
WORKING:
sql:
- name: MariaDB Database Size
column: "value"
device_class: data_size
LIMITATION:
There is no way to set the “scan_interval” from sensor. To be honest I have no idea how often it will update. I don’t see any config that allow me to define that.
But at least the sensor is there. Maybe not exactly how I wanted at first but it’s already a beginning. If I find a way to configure the update interval I’ll update this post.
Deoptim
(Dmytro)
July 4, 2023, 6:59am
17
you can use customize configuration to set scan_interval
for example:
homeassistant:
unit_system: metric
customize:
sensor.mariadb_database_size:
scan_interval: 3600
Ben-Da
(Ben-Da)
February 5, 2024, 8:09pm
18
The answer from X4V1 was not working for me, but gave me the hint to use sql instead of sensor.
I use this code
sql:
db_url: !secret mariadb_url
query: SELECT table_schema AS 'db_name', ROUND(SUM( data_length + index_length ) / 1024 / 1024, 2) AS 'size_mb' FROM information_schema.TABLES WHERE table_schema='homeassistant'
column: "size_mb"
grumete
(grumete)
December 9, 2024, 12:10pm
19
Gracias. Dos dias buscando y lo tienes tu la solución.
