You could just setup a template sensor, that get’s changed by an automation, triggered by the state change of the original sensor to: on. The last update timestamp of your template sensor should be the time, the original sensor was turned ‘on’ the last time. Depending on your system, it might be off by at most a few seconds.
EDIT: I always forget, we now have trigger based template sensors, that should work even better!
EDIT2: Something like this, not tested and written without checking the documentation, and from the top of my head, I’m not savy yet with these new template sensors.
So don’t be mad, if it doesn’t work from the beginning.
template:
- trigger:
- platform: state
entity_id: switch.tuya_f_socket_1
to: 'on'
- name: your_timestamp_on
state: "{{ now() }}"
