Although that does sort of go against the point of docker
I would have to read it again and I will, but will Acme renew the certificate automatically. Just checked crontab -l after Acme installation and it shows:
56 0 * * * “/home/homeassistant/.acme.sh”/acme.sh --cron --home “/home/homeassistant/.acme.sh” > /dev/null
It sure is much easier than using certbot - especially if auto renewal is included.
Thanks!
check the solution one post above yours solution, just put the ssl check script in the homeassistant config folder.
Thank you.
Ive installed the ssl-cert-check in homeassistant home folder, modified its permissions and modified the sensor to let it run in my configuration and give me “-days”
sersors.yaml:
- platform: command_line
command: /home/homeassistant/ssl-cert-check -b -c /home/homeassistant/.acme.sh/YOURNAME.duckdns.org/YOURNAME.duckdns.org.cer | awk '{print -$6}'
scan_interval: 43200
unit_of_measurement: days
ps: its build in: https://www.home-assistant.io/components/sensor.cert_expiry/
problem is with the builtin one, if you restart HA at any time it says unavailable. I think it only checks every 12 hours.
SSL Certificate Expiry
2 days ago
Unknown
via SSH work fine
For anyone looking for a easier method to keep the SSL cert valid, just run:
apt-get install certbot
systemctl enable certbot.timer
systemctl start certbot.timer
This will use the auto-update system defined by Let’s Encrypt itself.
I’m not experiencing that, if I restart it shows it immediately.
Is it possible to use the build in component with the URL: https://xxx.com:789/?src=connect
I have tried
host: xxx.com
port: 789
Since I switched to Caddy it’s working immediately here as well but with the standard LetsEncrypt addin it was a 12 hour wait to see the sensor expiry.
Same problem! Did you solve the problem?
I think is a user permission problem.
LS -la command show me “ssl-cert-check” file have a root:root permission, i think need change with “homeassistant” user.
To fix the delayed update after a system restart, I use an automation that runs 15 seconds after hass startup and calls the homeassistant.update_entity service for the sensor.ssl_certificate_expiry. This way it updates without the 12 wait.
Excellent! Thank you for the suggestion.
So you have something like that ?
- alias: update_entity_on_reboot
- platform: homeassistant
event: start
- delay: "0:00:30"
- service: homeassistant.update_entity
entity_id: sensor.ssl_certificate_expiry
Yes, that is correct. Works like a charm.
any idea why i do not see days?
any idea? my did not show any info.
Hi all. Does anybody know what is the name of variable/attribute for currently left days? I setup following automation to receive Pushbullet message:
- id: ‘1584111101296’
alias: SSL Certificate Expire
description: ‘’
- below: ‘4’
platform: numeric_state- below: ‘3’
platform: numeric_state- below: ‘2’
condition:- below: ‘4’
condition: numeric_state
entity_id: sensor.ssl_certificate_expiry- below: ‘3’
entity_id: sensor.ssl_certificate_expiry- below: ‘2’
action:- data:
message: Hi! This is automated message by Home Assistant - your SSL certificate
is expiring by {{ state_attr(‘sensor.ssl_certificate_expiry’, ‘???’) }} days!
- device/telephone
- email/[email protected]
- channel/my_home
service: notify.pushbullet_stiw47
What should I put in message body instead of question marks, in order to get number which is stated on lovelace?
Thanks.
states(‘sensor.ssl_certificate_expiry’)
Anyone who has come to this thread recently, please note this is quite an old thread and there are much better ways of doing this these days, like using an addon that automatically manages your certs, or use the built-in homeassistant sensor.
I’ve updated the OP with a similar note.
