I have also acquired an API key from Eskom se Push and implemented it.
Works fantastic!
Kudos to @swartjean, I am using his integration to make this all work.
For those of you that would like to implement something similar, I will post my code. Keep in mind that I am no developer so go easy on me. If you can use my code and modify it to be more “correct” / efficient then go for it.
type: vertical-stack
cards:
- type: markdown
content: |-
{% if states("calendar.loadshedding_local_events_2") == "off" %}
<font size=5 font color = green>Currently not Load Shedding</font>
{% elif states("calendar.loadshedding_local_events_2") == "on" %}
<font size=5 font color = red>Load Shedding in Progress</font>
{% endif %}
title: Load Shedding Status
- type: entity
entity: calendar.loadshedding_local_events_2
attribute: message
- type: entity
attribute: start_time
name: 'Next load shedding starts at:'
- type: markdown
content: >-
<font size = 06px><font color = red>{% if
Starts in: {{states('sensor.loadshedding_start_time')}}</font>
{% else %}
<font size = 06px><font color = green>Ends in:
{{states('sensor.loadshedding_end_time')}}
{% endif %}</font>
- type: entity
attribute: end_time
name: 'Next load shedding ends at:'
- initial_view: dayGridDay
type: calendar
entities:
- calendar.loadshedding_local_events_2
And then the template sensors for loadshedding_start_time and end_time:
#Loadshedding start time and end time sensors
sensors:
loadshedding_start_time:
value_template: >
{% set st = ((as_timestamp(state_attr('calendar.loadshedding_local_events_2','start_time')) - as_timestamp(now().timestamp()|timestamp_custom("%Y-%m-%d %H:%M:%S"))) / (60)|float)|round(0) | int %}
{% if st == 0 %}
Unavailable
{% elif st > 60 %}
{{ st // 60 }}:{{ '{:0>2d}'.format(st%60) }} hours
{% else %}
{{ st }} minutes
{% endif %}
sensors:
loadshedding_end_time:
value_template: >
{% set et = ((as_timestamp(state_attr('calendar.loadshedding_local_events_2','end_time')) - as_timestamp(now().timestamp()|timestamp_custom("%Y-%m-%d %H:%M:%S"))) / (60)|float)|round(0) | int %}
{% if et == 0 %}
Unavailable
{% elif et > 60 %}
{{ et // 60 }}:{{ '{:0>2d}'.format(et%60) }} hours
{% else %}
{{ et }} minutes
{% endif %}
