Hey @pazoozoo123 this is fantastic! I ran into the power_command_topic issue today and your “off mode” seems like a great resolution.
I’m already using the upstream version of your code GitHub - BobWatson/wmp2mqtt: Bridge from Intesis WMP protocol to MQTT as a docker Docker
Is there any chance you could also host a docker image and/or co-ordinate and push your changes upstream into BobWatsons release?
cheers
