I have upgraded to 2021.8.0 and the code still won’t work
Clearly you are doing something consistently different from what I and koying did (because we used the code you posted and it works for us). Unfortunately, neither of us knows what you are doing differently.
As an experiment, remove the regex pattern from the configuration of input_text.pin_eingabe (and them, just for good measure, execute Configuration > Server Controls > Reload Input Texts). Now try to use a Button Card as originally configured:
type: button
tap_action:
action: call-service
service: input_text.set_value
service_data:
value: '000000'
entity_id: input_text.pin_eingabe
If that still fails to work then I’m out of ideas to identify the root cause of this problem.
I removed the regex, and it still won’t work, the same damn error Like before
Everything you explained and provided can be duplicated on another system but without the error. Therefore there is a missing piece to this puzzle; there is something about your system’s configuration, or the way it is using that Button Card, that is different from my system and koying’s. Unfortunately, I can’t think of what that missing clue might be.
Hence my question ![]()
That’s the code where the button is. It’s the last thing on this page:
- title: Admin
path: admin
visible:
- user: 75a4ceb3b1e24e8689e677fd9ed2a83f
panel: false
badges:
- entity: sensor.aarons_zimmer_temperature
- entity: sensor.aarons_zimmer_light_level
- entity: sensor.bad_bwm_temperature
- entity: sensor.bad_bwm_light_level
- entity: alarm_control_panel.ha_alarm
- entity: counter.dimmer_aus_gedruckt
cards:
- type: button
tap_action:
service: script.1628016560072
service_data: {}
target: {}
show_icon: false
- type: custom:bignumber-card
entity: sensor.otp_3
color: red
icon: mdi:matrix
entity: sensor.otp_2
color: yellow
entity: sensor.otp
color: green
entity: sensor.otp_sensor
color: white
icon: mdi:matrix
- type: conditional
conditions:
- entity: sensor.blitzortung_lightning_counter
state_not: '0'
card:
type: entities
entities:
- entity: sensor.blitzortung_lightning_azimuth
secondary_info: last-changed
- entity: sensor.blitzortung_lightning_distance
show_header_toggle: false
title: Blitze
- type: entities
entities:
- entity: input_boolean.standort
- entity: input_boolean.musik_sonos_auslosen
- entity: input_boolean.genauer_standort_aaron
- type: custom:scheduler-card
title: false
include:
- light
- media_player
- notify
- switch
discover_existing: true
time_step: 1
- type: horizontal-stack
cards:
- type: button
tap_action:
action: toggle
entity: input_boolean.led_bad
- type: button
tap_action:
action: toggle
entity: input_boolean.led_esszimmer
- type: button
tap_action:
action: toggle
entity: input_boolean.led_keller
- type: button
tap_action:
action: toggle
entity: input_boolean.led_schlafzimmer
- type: button
tap_action:
action: toggle
entity: light.handy_aaron_app
show_icon: true
icon: hass:switch
- type: alarm-panel
states:
- arm_away
- arm_home
- arm_night
- arm_custom_bypass
- arm_vacation
theme: day_and_night
- type: entity
entity: device_tracker.oneplus_nord
- type: button
tap_action:
action: navigate
navigation_path: /alarm-0/alarm-0/
theme: happy
hold_action:
service: camera.play_stream
service_data:
media_player: media_player.aarons_alexa
entity_id: camera.camera1
icon: mdi:camera-control
- type: sensor
entity: sensor.cpu_temperature
hours_to_show: 72
detail: 2
graph: line
name: 'CPU Temperatur '
- type: gauge
entity: sensor.openweathermap_rain
min: 0
max: 100
severity:
green: 0
yellow: 20
red: 40
theme: auto
- type: gauge
entity: sensor.openweathermap_cloud_coverage
min: 0
max: 100
severity:
green: 10
yellow: 50
red: 70
- type: entities
entities:
- device_tracker.ac2003
- sensor.ac2003_active_notification_count
- sensor.ac2003_app_importance
- sensor.ac2003_app_memory
- sensor.ac2003_app_rx_gb
- sensor.ac2003_app_tx_gb
- sensor.ac2003_audio_mode
- sensor.ac2003_battery_state
- sensor.ac2003_battery_temperature
- sensor.ac2003_ble_transmitter
- sensor.ac2003_bluetooth_connection
- sensor.ac2003_charger_type
- sensor.ac2003_detected_activity
- binary_sensor.ac2003_device_locked
- sensor.ac2003_do_not_disturb_sensor
- sensor.ac2003_geocoded_location
- binary_sensor.ac2003_headphones
- binary_sensor.ac2003_interactive
- sensor.ac2003_internal_storage
- binary_sensor.ac2003_is_charging
- binary_sensor.ac2003_keyguard_locked
- sensor.ac2003_last_notification
- sensor.ac2003_last_reboot
- sensor.ac2003_last_removed_notification
- sensor.ac2003_last_update_trigger
- sensor.ac2003_light_sensor
- sensor.ac2003_media_session
- binary_sensor.ac2003_music_active
- binary_sensor.ac2003_power_save
- sensor.ac2003_proximity_sensor
- sensor.ac2003_public_ip_address
- sensor.ac2003_ringer_mode
- sensor.ac2003_sleep_confidence
- sensor.ac2003_sleep_segment
- binary_sensor.ac2003_speakerphone
- sensor.ac2003_steps_sensor
- sensor.ac2003_total_rx_gb
- sensor.ac2003_total_tx_gb
- sensor.ac2003_volume_level_alarm
- sensor.ac2003_volume_level_call
- sensor.ac2003_volume_level_music
- sensor.ac2003_volume_level_ringer
- sensor.ac2003_wifi_bssid
- sensor.ac2003_wifi_connection
- sensor.ac2003_wifi_frequency
- sensor.ac2003_wifi_ip_address
- sensor.ac2003_wifi_link_speed
- sensor.ac2003_wifi_signal_strength
- binary_sensor.ac2003_wifi_state
- type: entities
entities:
- sensor.ipad_von_aaron_activity
- sensor.ipad_von_aaron_battery_state
- sensor.ipad_von_aaron_bssid
- sensor.ipad_von_aaron_connection_type
- sensor.ipad_von_aaron_last_update_trigger
- sensor.ipad_von_aaron_ssid
- sensor.ipad_von_aaron_storage
- type: entities
entities:
- binary_sensor.updater
- type: picture-entity
entity: camera.camera1
- type: custom:notify-card
target: notify.mobile_app_ac2003
tag: locupdate
- type: button
tap_action:
service_data:
value: '000000'
