I remember now. I manually edited the sensor.py file. It’s only 1 line that needs a change.
ShadCrow
(Shad Crow)
June 14, 2022, 2:23am
42
I ended up creating a new feature request that as a high level summary to attempt to improve discoverability of those afflicted by this issue. If anyone has a better idea of how to resolve this, please continue to share:
Situation: As reported by others, there appears to be a bug that has not been documented here that causes failed authentication with a specific, but common, workflow.
Have a picture entity (or camera?) on the screen of the device you are using (Xiomi map integration is one such example)
Put the device to sleep (tested on phone app, but it appears kiosk devices act similarly so I would assume this also may impact computers).
Return to the device after some time.
Of note, the above workflow was…
Escovan
(Jelle van der Pal)
May 12, 2024, 11:01am
43
Yes. If this is about a cheap Tuya camera, I think your suggestion just solved my question as to why my own IP got locked out.
