Set color and brightness by automation
Im trying to create an rule to turn a shelly Duo RGB-bulb by a (433-)switch.
The rule I try to use is this:
- id: 'xxxxxx'
  alias: UtelysOn
  description: ''
  - platform: device
    type: turned_on
    device_id: yyyyyy
    entity_id: switch.utelyssoft
    domain: switch
  condition: []
  - type: turn_on
    device_id: zzzzz
    entity_id: light.utelys
    domain: light
      brightness: 130
      rgb_color: [255,0,0]
HA -response:
Logger: homeassistant.config
Source: config.py:455
First occurred: 14:53:04 (1 occurrences)
Last logged: 14:53:04
Invalid config for [automation]: [data] is an invalid option for [automation]. Check: automation->data. (See /config/configuration.yaml, line 8).
I guess I need some guiding here…
Use the light.turn_on service instead of the device turn on action.
Also read this rant about device triggers, conditions and actions (in short, don’t use them).
Thanks, solved
