Is there any way to set the source on Sonos devices?
I have a pair of Play:5’s that I want to set to Line-in ® when I turn on my TV.
Bumping this to provide the answer, since this is the top result for this question on Google.
The sources listed in HASS are your Sonos favorites as-of startup, but since you can’t favorite a line-in, you can’t use media_player.select_source
. Instead, you’ll have to use media_player.play_media
and tell Sonos which specific speaker’s line-in you want to use.
Open the Sonos app, and visit Settings > About my Sonos System, then find the device whose Line-in you want to use. Look at the part of the serial number before the :
, and remove any dashes. Your ID is: RINCON_XXXXXXXXXXXX01400
(replace the Xs with your serial number).
For example, if my serial was 01-23-45-67-89-AB:F
, my ID would be RINCON_0123456789AB01400
(Alternatively, just visit http://[sonos device id]:1400/status/zp
and make note of the LocalUID
You can call media_player.play_media
with the following:
entity_id: media_player.[...]
media_content_id: x-rincon-stream:RINCON_[...]
media_content_type: music
EDIT 2021: At some point media_content_type
switched from “MUSIC” (uppercase) to “music” (lowercase). If you’re having any problems, try the opposite casing.
It was probably updated, cause for me it works with:
entity_id: media_player.sonos_arc
source: TV
This works for me now, (possibly because it’s using the line-in from itself):
- service: media_player.select_source
entity_id: media_player.basement_sonos
source: Line-in
- service: media_player.media_play
Thank you! now we need to add ‘data’ with last upgrade:
entity_id: media_player.salle_tv
source: TV
Thanks for this, very helpful.
In case someone want to use this with Node-Red, here is the service node to call.
[{"id":"fe19f54a.0edbe","type":"api-call-service","z":"776f4844.419d2","g":"19f4a5c7.121f4a","name":"Vinyl to Salon","server":"3c58bfa4.fb4fb","version":3,"debugenabled":false,"service_domain":"media_player","service":"play_media","entityId":"media_player.name","data":"{\"media_content_id\":\"x-rincon-stream:RINCON_XXXXXXXXX01400\",\"media_content_type\":\"music\"}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":720,"y":120,"wires":[[]]},{"id":"3c58bfa4.fb4fb","type":"server","name":"Home Assistant","version":1,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
Thanks works great:blush:
is this still working, what is the latest trick. i can’t get Line-In to work. Thx
actually got it to work this way
Example: (‘Apple TV Family Room: Family Room: Family Room’, ‘FV:2/0’)
I am new to HA and can’t seem to work out how to select the Line-in on a Sonos Connect. I have tried this but to no avail:
source: Line-in
entity_id: media_player.study_connect
I have also tried:
service: media_player.play_media
media_content_id: x-rincon-stream:RINCON_949F3E26375E01400
Well it turns out the last one above was working, but when I ran the script from within the script editor it did nothing.
When I exited it and ran it from the the 3 dots menu against the same script it worked. I don’t understand then.
If you go to the sidebar menu → Developer Tools → States, find your speaker, and click on it, you’ll see the full state in a YAML textarea. Part of that YAML is a source list similar to the following:
source_list:
- Line-in
- TV
If you use one of these as your source when calling media_player.select_source
, it should work. Make sure to use the exact case from the list.
I’d imagine this solution is less likely to break with an update, but the rincon URL solution above will allow playback of one device’s input through a different speaker
