I tried some things because i encountered the same problem but i got it fixed setting the variable attributes. I must say im pretty new to this type of coding and find it hard to get used to so my approach is mostly the trial and error method
i have a problem with set the variable a (i don’t write anything in configuration.yaml i have write all code inside only in automation.yaml) with this my automation to find increase temperature
can you help me ? i don’ t know how i can resolve …
- alias: Controllo_incremento_temperatura301
- platform: state
entity_id: switch.sonoff_XXXX
to: "on"
- variables:
start_temperature301: "{{ states('sensor.sonoff_XXXX_temperature') }}"
#counter: 0
- alias: repeat until
repeat:
sequence:
- delay: 00:00:03
- variables:
new_temperature301: "{{ states('sensor.sonoff_XXXX_temperature') }}"
- choose:
- conditions:
- condition: template
value_template: "{{ (float(start_temperature301) + 0.1) < float(new_temperature301) }}"
sequence:
- variables:
a: 2 # this don't work
- service: notify.mail
title: "Controllo Istantaneo temperatura 301"
message: "Incremento di 0.1 gradi rilevato"
default:
- variables:
a: 1 # this don't work
until:
condition:
- or:
value_template: "{{ a != 2 }}"
value_template: "{{ repeat.index > 20 }}"
title: "STATO CALDAIA ENTRO 15 MIN DA ACCENSIONE CALDO 301"
message: >
{% if a == 1 %}
ALERT_CALDAIA NON FUNZIONANTE ENTRO 15 MIN_DOPO 301 CALDO ON
{% elif a == 2 %}
OK_CALDAIA FUNZIONANTE ENTRO 15 MIN_DOPO 301 CALDO ON
{% else %}
PROBLEMA NEL CODICE
{% endif %}
how can i set variable a to 1 or 2
a=1 or a=2 ???
is the only tings that don’t work in this automation …
Good afternoon, I am trying to put an automation script together based off a Schedule. The challenge I have is setting the value of HVAC (Off or Heat) from a Scheduler (Off or On) - sorry for the ramble…
Schedule sends ‘on’ or ‘off’ based time, this works as I can include the state in a notification.
The switch takes hvac_mode: ‘off’ or ‘heat’
In my automation I need to map ‘on’ from the schedule to ‘heat’ and then use this variable in hvac_mode: %variable%
alias: Boiler Control - Weekdays PM
description: Boiler Control - Weekdays PM
- platform: state
entity_id:
- schedule.boiler_weekday_pm
attribute: next_event
condition:
value_template: "{{ trigger.to_state.state in ['on', 'off'] }}"
- service: climate.set_hvac_mode
metadata: {}
**hvac_mode:** heat # needs to be a variable set by "trigger.to_state.state"
entity_id: climate.controller_boiler
- service: notify.mobile_app_carey_work_phone
metadata: {}
message: "\"Boiler switched {{ states('switch.controller_boiler') }}\""
mode: single
