One suggestion would be to use NGINX - it will enable you to run Home Assistant in NON-SSL mode and will proxy the connection for you. That would mean that from outside you could access HASS as usual, but internally, ApDaemon could talk to HASS over a regular HTTP connection, and you could access HASS internally using the IP address instead of DSuck DNS. I have this setup and it works well.
Actually I’d never been able to run HA on my network with the duckDNS domain, never, and I thoughted this was normal I do am abe to access HA from the outside with just the duckDNS domain (httpS://xxx.duckdns.org) but internally I have to use httpS://192.168.xx.xxx:8213 and the same is for my mosquitto broker, externally I can call it using dukDNS domain but internally i have to use httpS://192.168.xx.xxx:portNumber
So is this not a normal behaviour? (As I ould love to be able to run HA from one single URL instead of chnging each time I leave my network reason why I prefere tosolve that instead of using NGINX and by the way hairpinning it seems it’s not supported by my router )
Normal is a moot point, but it is the source of your problem. Most routers have the ability to understand this and map it back into your domain, but some can;t. If you use the IP address you get an SSL security violation because the IP doesn not match the expected hostname in the CERT, I am not aware of a way around that with the libraries I am using. My suggestion would be to go down the NGINX route and leave HASS running over HTTP, with NGINX proxying the outside SSL access for you.
Haha, agree… it’s a moot point. After your post decide to set up NGINX and I almost had success.
It instaled correctly and it’s running but actually I opened a post because I’m having the dollowing bad behaviour with nginx.
By chance, do yo know how can I fix this? (Beacuse obviously as NGINX it’s not working properly I’m still unable to run appDeamon)
If I use my “regular/normal” way to access HA internally using httpS://192.168.xx.xxx:8123 it works as usual
The strangest thing to me; If I use http://xx.duckdns.org (without the S) from inside my network, it now shows the router’s config webpage (the one that I should acess with 192.168.1.1) (before NGINX that duckDNS address was not accessible)
If I use httpS://xx.duxkdns.org (using the S) from inside my network it says that the webpage it’s not accessible (the same message as ever)
If I try to acces the duckdns URL (with http:// or with https://) from the outside it’s impossible access to HA
After doing that (remove the 2 cert rows in the http section of my config.yaml I’m able to access internally with the IP of the RPi3 witout using any port or the “s” in http, so I can use 192.168.xx.xx and it works
The only really strange thing and wich actually is preventing me to use AppDeamon is;
if I use http://xxx.duckdns.org internally sends me directly to my router’s webpage
And if I use httpS://xxx.duckdns.org it doesn’t work as always
Do you know why this could be and how to fix it? (Just as a reminder my router don’t support loopback)
Also why the “trusted network” it doesn’t work anymore?
