so if you add or modify an entity, how do you get GA to recognize this.
I changed name of switch from switch.southdoor to switch.entrydoor.
GA still had it as switch.southdoor and I could not get this to change
ultimately I “unlink” my account then “link” my account again. This updated name.
Perhaps you just need to wait. GA is seeing the exposed domain so if you add/remove an entity from a domain it should refresh in the GA app but maybe it’s not instantly.
I have followed every step on https://home-assistant.io/components/google_assistant/ successfully but when I want to add my device on the Google Home app I always get an error “The setting could not be updated. Check your connection.”.
What could be the problem and solution?
This must be an exceedingly stupid question, but I get stuck at step 6
Open the Google Assistant app and go into Settings > Home Control
I can’t find an app called Google Assistant on my phone, nor a setting Home Control in any Google app I can find on my phone. Can anybody point me to the right direction?
Thanks for your help. Do you mean app called ‘Google’ with the search bar and than card for local weather, traffic and news? If I go to settings I get a list with Notifications, Accounts & Privacy, Search Language, but no Home Control.
Im trying to setup google assistant, but im stuck on step 1 believe it or not…
Install the gactions CLI (you’ll use this later) - you can download this anywhere, just remember where you put it for later (and don’t forget to run chmod +x gactions)
Where do i install gactions CLI? On my windows pc or the pi? If on the pi, how do i install it? And where/what/how do i run chmod +x gactions?
Create a new file named project.json (in the same directory you downloaded gactions to) and replace the [YOUR HOME ASSISTANT URL] below with the URL you use to access Home Assistant. Note: This must be an HTTPS URL to work.
And here, does this mean i need to have a duckdns url setup? with encryption?
