however I would like to have an answer only about the temperature without the state of the sensor.
Instead of “It’s currently 25 degrees and the kids room is off”
The Google Console is asking for a “Token URL” which is not mentioned in the instructions. The description given is “OAuth2 endpoint for token exchange”.
Anyone one else not able to add other members? The test app shows in my home control but for the last few days, no matter what I do, I can’t get it to show in any other user’s Home Control app. I’ve checked everywhere from FireBase to Actions console to GCP IAM. Everything looks right (all other users are set to Project->Editor) but no matter what I do, I can’t get the test app to show up for them.
Interestingly, when I create a new test app on another users account, it shows up for them but when I add myself it doesn’t.
Just wanted to know if anyone else was experiencing this too?
update: apparently, it doesn’t matter. Wife can still call for lights and interact with DialogFlow despite not having the test app appear for her.
Genius! This helped me solve an issue I have had with HA/Google Assistant for the last few weeks. This had been working for about six months, but then stopped, and I couldn’t re-link the working project within The Google Home app on the phone to HA.
Recreating the project in Google Console didn’t work.
I had tried deleting the brower cache in Chrome on the Android phone, but that didn’t work either.
Logging out of Chrome on Android phone fixed this. When I added the [test] app with the Google app on the phone it then switched me to Chrome and prompted for credentials, which it adn’t done before. After that the [test] app linked!
My issue with the relinking this time around was that I was using the same HA url for both step 1 and step 2 when in fact step 2 has ‘auth’ in the URL.
I have google assistant working for more than a year with Duckdns and letsencrypt.
I would like to also install nginx.
So i configured everything as docs said.
I comment
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
in order to have ssl termination on nginx
Nat 443 port on my router.
And everything works as it should except google assistant.
When i try to unlink and link again i go to authentication page,
insert credentials but then i get “Couldn’t update the setting. Check your connection”
