Ok I will try it thanks
@thusassistint Hey again,
I did try you code, but after a upgrade the ESP Controller with a new firmeware. I got wrong values.
I saw two issue:
The state was: 10241.504
After upgrade the counter got the value 10241 pulses and then multiply with 0.001 so the global state was 10.241
- First problem the decimal places were gone
- Second i think i have to multiply with 1000 but not sure during
on_shutdown
oron_boot
and how
Do you have an idea? Thank you
Reading this and many other topics i try to get my water meter running that has installed a proximity meter. When it turns the light on the proximity meter on every time the wheel passes. Every passage should be 1 liter of water but. The code is easy and simple and you find it on many places over the web ( i used pieter brinkmans code but there are many others) I also tried pulse meter and pulse counter. But every time the led goes red the log shows 80-120 pulses (fluctuating a little) instead of 1. I use a D1 mini and connected it to D4 - GPIO2. Questions i have might it be possible that the time the red light is on(so the pulse is on) it measures the time itβs on and shows in a way so many pulses ? or did i not use the correct pin on the D1 mini or something .
