I think I’d rather give the support here rather than on github if you don’t mind. It’s harder for me to work in the issues section than here…
I see that you are referencing a “sensor.nws_alert_event” and the attributes you list as seeing looks like just a raw printout of the actual returned values from the NWS API itself. that is totally different than the way the attributes of the integration looked.
But then in referencing the new integration the sensor is called “sensor.nws_alerts” as expected for the default config of the integration.
the old version of the integration attributes looked something like this:
con: mdi:alert
friendly_name: NWS Alerts CA
attribution: Data provided by Weather.gov
title: Flash Flood Warning - Flood Warning - Excessive Heat Warning
event_id: https://api.weather.gov/alerts/urn:oid:2.49.0.1.840.0.062adf8f774208d4b0301b8ac64107167c49c6a8.001.1 - https://api.weather.gov/alerts/urn:oid:2.49.0.1.840.0.2a856572766cc0bbdf80ffb871408eaf287d1e46.001.1 - https://api.weather.gov/alerts/urn:oid:2.49.0.1.840.0.cf5b013516d8b5a423702d735823505819207f26.001.2
message_type: Update - Alert - Alert
event_status: Actual - Actual - Actual
event_severity: Severe - Severe - Severe
event_onset: 2024-08-17T08:47:00-05:00 - 2024-08-17T08:01:00-05:00 - 2024-08-17T12:00:00-05:00
event_expires: 2024-08-17T11:00:00-05:00 - 2024-08-17T11:00:00-05:00 - 2024-08-17T15:15:00-05:00
display_desc:
Headline: Flash Flood Warning
Status: Actual
Message Type: Update
Severity: Severe
Certainty: Likely
Onset: 2024-08-17T08:47:00-05:00
Expires: 2024-08-17T11:00:00-05:00
Description: FFWTSA
The National Weather Service in Tulsa has extended the
* Flash Flood Warning for...
Southwestern Sebastian County in west central Arkansas...
East Central Haskell County in southeastern Oklahoma...
Central Le Flore County in southeastern Oklahoma...
* Until 1100 AM CDT.
* At 847 AM CDT, Doppler radar indicated thunderstorms producing
heavy rain across the warned area. Between 2 and 4 inches of rain
have fallen. Additional rainfall amounts up to 2 inches are
possible in the warned area. Flash flooding is ongoing or expected
to begin shortly.
HAZARD...Flash flooding caused by thunderstorms.
SOURCE...Radar.
IMPACT...Flash flooding of small creeks and streams, urban
areas, highways, streets and underpasses as well as
other poor drainage and low-lying areas.
* Some locations that will experience flash flooding include...
Poteau... Pocola...
Heavener... Spiro...
Panama... Wister...
Hackett... Howe...
Hartford... Huntington...
Keota... Bokoshe...
Midland... Cameron...
Lake Wister State Park... Shady Point...
Rock Island... Patterson...
Cowlington... Scullyville...
Instruction: Turn around, don't drown when encountering flooded roads. Most flood
deaths occur in vehicles.
Headline: FLOOD WARNING IN EFFECT UNTIL 11 AM CDT THIS MORNING
Status: Actual
Message Type: Alert
Severity: Severe
Certainty: Likely
Onset: 2024-08-17T08:01:00-05:00
Description: * WHAT...Flooding caused by excessive rainfall is expected.
* WHERE...Portions of Arkansas, including the following counties,
Crawford and Sebastian and Oklahoma, including the following
counties, Le Flore and Sequoyah.
* WHEN...Until 1100 AM CDT.
* IMPACTS...Flooding of rivers, creeks, streams, and other low-lying
and flood-prone locations is imminent or occurring. It will take
several hours for all the water from these storms to work through
local drainage systems in urban areas.
* ADDITIONAL DETAILS...
- At 800 AM CDT, Flooding is ongoing due to earlier
thunderstorms. Additional lighter showers and thunderstorm
will move through the warned area through the morning.
Between 2 and 5 inches of rain have fallen.
- Additional rainfall amounts up to 0.5 inches are possible in
the warned area.
- Some locations that will experience flooding include...
Fort Smith... Van Buren...
Sallisaw... Pocola...
Muldrow... Roland...
Arkoma... Hackett...
Bonanza... Gans...
Moffett... Fort Smith Regional
Airport...
Cottonwood... Braden...
Scullyville... Mill Creek...
Dora... Rye Hill...
- http://www.weather.gov/safety/flood
Headline: EXCESSIVE HEAT WARNING IN EFFECT FROM NOON TODAY TO 9 PM CDT THIS EVENING
Status: Actual
Message Type: Alert
Severity: Severe
Certainty: Likely
Onset: 2024-08-17T12:00:00-05:00
Expires: 2024-08-17T15:15:00-05:00
Description: * WHAT...Dangerously hot conditions with heat index values 110 to
115 degrees expected this afternoon.
* WHERE...In Arkansas, Crawford, Franklin, and Sebastian Counties.
In Oklahoma, Sequoyah, Craig, Nowata, and Washington OK Counties.
* WHEN...From noon today to 9 PM CDT this evening.
* IMPACTS...The combination of hot temperatures and high humidity
will create a dangerous situation in which heat related illnesses
are more likely.
Instruction: An Excessive Heat Warning means conditions will accelerate the onset
of heat related illness, which may result in a shorter response time
to potential heat exhaustion and heat stroke.
To reduce risk during outdoor work, the Occupational Safety and
Health Administration recommends scheduling frequent rest breaks in
shaded or air conditioned environments. Anyone overcome by heat
should be moved to a cool and shaded location. Heat stroke is an
emergency! Call 9 1 1.
spoken_desc: Flash Flood Warning
again the attributes you posted on github are in a completely different format than the example I posted.
and as you can see in my example the “Headline:” attribute is in the same format as the current integration.
What I think is happening is that you are mistaking a different sensor (one that retrieves the raw data directly from the NWS API) for the old integrations sensor.
in the old package I think I put a raw API data sensor in there for comparison when I switched from the curl command_line to the integration many years ago and I think you may be seeing that old sensor thinking it’s the old integration sensor.
FWIW, you can still use that old sensor format and get the same data as you did before.
But the old integration and the new integration provide the same data.
does that make sense?
