It has very poor reception when connected to the Conbee but for about three days it was connected through the router and it had much better reception.
Is there any way to lock it to a router?
The really annoying thing with this device (for me with poor reception) is that it has the pairing button behind the mount.
So I first have to take it off the mount then re-pair and mount it again.
But apart from that it seems to work fine.
Nice that it works with conbee II. May I ask how precise is this sensor when the rain stops? Right now I have a water leak sensor for rain and the main problem is that it reports that the rain stopped after at least 1-2 hours than the actual time the rain stopped (until it dries)
Since you already have the conbee I think you will know the answer for my next question (unrelative). Can I add a sonoff zigbee device to use it as zigbee2mqtt?
I have read that the sonoff dongle is better than conbee (wider range etc) but I don’t want to remove conbee and reallocate all my sensors
If you look at the image above it seems to detect dry rather quick.
Much quicker than I expected.
Perhaps something is not correct, I’m not home at the moment.
But it said wet at 9:45, then 9:54 it was dry.
This could be a smal drop that it first detected then it dried or dripped off.
It has not rained when I have been home while this device also worked since I got it.
This has been the first test today actually.
Hi, how are you happy with that? I need some solution that will measure my lighting intensity because of solar panels. If the electricity purchase price is low, the solar panels don’t produce anything because the overflows are turned off and so I can’t see data-wise if the sun is shining, but I would need to know if I can turn on high EV charging or turn on the heating.
As a test, I have ordered a few of these new IKEA light/motion sensors to but against a window for using the light sensor to control lights based on the outside luminescence.
They are cheap and use AAA batteries.
According to this image the ZigBee antenna is right up against the Li-ION battery. You can see the antenna on the zigbee microcontroller in the cut-out in the green PCB. That would reduce the range in the direction outward of where the battery is located as the outer shell of the battery is made of steel.
Maybe in some situations where the sensor is performing poorly you could try rotating it 90 degrees and see if the RSSI improves over a period of hours.
I’m having problems with my newly arrived Tuya, but I think my problems are that it’s not getting enough light to charge the batteries properly. It will probably be a few days before I know for sure. The battery level isn’t responding so I can’t check for sure, but given it goes fine for a few hours and then drops off, I’m willing to bet that lack of sun is probably my issue.
