Hi!
I’m new to Home-Assitant, i’ve spent almost one week trying to solve this issue on my own, but now i need your help.
I’m running Hass.io and it seems i’m not able to run commands from the shell, both using shell_command and command_on/off.
This is my configuration.yaml:
shell_command:
shutdown_pc: ‘net rpc shutdown -I 192.168.X.X -U user%pass’
switch:
platform: wake_on_lan
host: “192.168.1.4”
mac_address: “XX-XX-XX-XX-XX-XX”
turn_off:
service: shell_command.shutdown_pc -
platform: command_line
switches:
kitchen_light:
command_on: “touch /tmp/on.txt”
command_off: “/usr/bin/net rpc shutdown -I 192.168.X.X -U user%pass”
Noting seems working, no file is created in /tmp/ and no shutdown.
If i run them from a SSH shell (root user) everything is working fine, but from the GUI they are not working.
If i look into the logs i see:
2017-10-07 16:23:24 ERROR (SyncWorker_15) [homeassistant.components.switch.command_line] Command failed: /usr/bin/net rpc shutdown -I 192.168.X.X -U user%pass
Could you please help me? It is a permission error?
EDIT: i don’t know how to make the code looks good on the forum, sorry
