Shell_command / ssh: return_code 255
Here is a link you might find helpful
A couple of thoughts:
  • When you run it manually to see if it works, make sure you do so inside the homeassistant container and note that its config path is /config.
  • Follow the guide, as you’ll need an ssh option to deal with the fingerprint reply from the remote host
