The device name is missing, maybe problem with the firmware. Update firmware and/or add a device name.
Thank you. This worked. I added a custom name to the device and a name for the output.
I appreciate your help over in the gen1 script thread, but this is a related gen2 script question so I moved it here. Fo you have any idea why some plus 1 devices would populate the input0 entity and some would not? This is what Iâm seeing. 4 of the devices show a disabled input 0, and 2 do not.
Input sensors are only created if the input type is switch
Thanks⌠got it. I also have an issue that the âextraâ info like last restart, relay temp, wifi strength, etc. isnât coming across MQTT on the same 2 out of 6 plus1âs. Is there another setting Iâm missing for this?
Do you use automations from the last version of the script? Does the js script is correctly installed and running on every device?
I just installed it for the first time so I assume so⌠I could delete the script from the device and try to reprovision it I suppose?
Using the exact same process, 4 of the plus 1âs worked fine, 2 did not.
If the device was originally provisioned as a button, and then changed to a switch, does the script need to be deleted and reinstalled?
Every configuration changes are populated to the MQTT configuration after HA restart (assuming that shellies_discovery and shellies_announce automation are added correctly).
Let me know if thereâs any other info I can capture to help debug. Iâm not sure what else to look for. Would you just factory-reset the Plus1âs and try again at this point? Looking for ideas.
Here is the script that is contained in the device (same on 4 working and 2 not-working units):
let topic_prefix = null;
let installed_version = null;
Shelly.call("MQTT.GetConfig", {}, function (config) {
topic_prefix = config.topic_prefix;
function SendDeviceStatus() {
let _device_info = Shelly.getDeviceInfo();
installed_version = _device_info.ver;
Shelly.call("Shelly.GetStatus", {}, function (status) {
status.sys.installed_version = installed_version;
MQTT.publish(topic_prefix + "/status/rpc", JSON.stringify(status));
MQTT.setConnectHandler(SendDeviceStatus);
let UpdateTimer = Timer.set(30000, true, SendDeviceStatus);
Here is the header from shellies_discovery_gen2.py:
"""This script adds MQTT discovery support for Shellies Gen2 devices."""
VERSION = "2.20.0"
Here is what is included in my automations.xml.
- id: shellies_announce_gen2
alias: Shellies Announce Gen2
- platform: homeassistant
event: start
variables:
device_info_payload: '{{ {''id'': 1, ''src'':''shellies_discovery'', ''method'':''Shelly.GetConfig''}
| to_json }}'
device_ids:
- garage/shellyplugus-c049ef895404
- garage/shellyplus1-b8d61a87d2b0
- garage/shellyplus1-b8d61a8c38d8
- shop/shellyplus1-b8d61a880604
- bar/shellyplus1-b8d61a8c3538
- theater/shellyplus1-b8d61a87d024
- exercise/shellyplus1-b8d61a8a9420
- repeat:
for_each: '{{ device_ids }}'
sequence:
- service: mqtt.publish
topic: '{{ repeat.item }}/rpc'
payload: '{{ device_info_payload }}'
- id: shellies_discovery_gen2
alias: Shellies Discovery Gen2
mode: queued
max: 999
- platform: mqtt
topic: shellies_discovery/rpc
- service: python_script.shellies_discovery_gen2
id: '{{ trigger.payload_json.src }}'
device_config: '{{ trigger.payload_json.result }}'
topic: '{{ trigger.payload_json.result.mqtt.topic_prefix }}/command'
payload: status_update
I just ran an MQTT logger and came to realize that 6 of the 7 devices arenât actually sending their status on a regular basis. They are very responsive to commands, and the webgui is easily acceptable (so probably not a wifi strength issue?), but are not sending any MQTT messages regularly.
Only 1 device is refreshing the shellyplus1-xxxxxxxxxxxx/status/rpc topic every 30s as expected.
My gen1 devices (dimmer2) are in the same physical location in many cases and appear to be working perfectly.
Any ideas?
Pro/Plus devices donât send data periodically, they send data when the data changes. For non-PM devices, this means you need a js script that forces the data to be sent periodically. The script is probably disabled or not working on your devices.
Sounds like it. What triggers the script to run? Do you have any suggestions on how to debug this?
I think figured it out. If you go to the webgui scripts tab and manually hit âplayâ, it starts again. I assume the switch there means âautorunâ but it wasnât obvious at all. Weâll see if it keeps working.
Is there a way to set the âexpire afterâ MQTT sensor property? I see how to do this for a gen1 custom config but not for gen2. I have an H&T sensor that only sends updates every 5 min and shows unavailable inbetween.
No. The script uses the device configuration to properly configure the entity.
Can you help me with why my H&T shows unavailable then despite getting a data packet every five minutes
Sure, open an issue on GH and attach a debug log for python script component.
Hello @Bieniu !
Thank you so much for this hard work.
I try to make GitHub - bieniu/ha-shellies-discovery-gen2: Script that adds MQTT discovery support for Shellies Gen2 devices script to work, but with no success, my shelly pro 1 isnât detected.
What Iâve done so far :
- install a mosquitto mqtt broker
- setup shelly device to connect to that broker. It seems successful, its status is connected. See
- add mqtt integration in HA and connect it to mosquitto broker. Seems to be fine too, but Iâm not sure on how to perfectly chek that.
- manually install your ha-shellies-discovery-gen2 script. Change configuration.yaml and automation.yaml as described in the doc. These is my automation.yaml file :
alias: "Shellies Announce Gen2"
event: start
variables:
device_info_payload: "{{ {'id': 1, 'src':'shellies_discovery', 'method':'Shelly.GetConfig'} | to_json }}"
device_ids: # enter the list of device IDs (MQTT prefixes) here
- shellypro1-30c6f7813e68
- repeat:
for_each: "{{ device_ids }}"
sequence:
topic: "{{ repeat.item }}/rpc"
payload: "{{ device_info_payload }}"
alias: "Shellies Discovery Gen2"
mode: queued
max: 999
- platform: mqtt
id: "{{ trigger.payload_json.src }}"
device_config: "{{ trigger.payload_json.result }}"
topic: "{{ trigger.payload_json.result.mqtt.topic_prefix }}/command"
payload: "status_update"
- enabled debugging log as explained in the doc. These are the logs Iâve got :
2023-10-29 10:24:57.320 INFO (MainThread) [homeassistant.components.automation.shellies_announce_gen2] Shellies Announce Gen2: Running automation actions
2023-10-29 10:24:57.321 INFO (MainThread) [homeassistant.components.automation.shellies_announce_gen2] Shellies Announce Gen2: Repeating sequence: Iteration 1 of 1 with item: 'shellypro1-30c6f7813e68'
2023-10-29 10:24:57.321 INFO (MainThread) [homeassistant.components.automation.shellies_announce_gen2] Initialized trigger Shellies Announce Gen2
2023-10-29 10:24:57.321 INFO (MainThread) [homeassistant.components.automation.shellies_discovery_gen2] Initialized trigger Shellies Discovery Gen2
2023-10-29 10:24:57.322 INFO (MainThread) [homeassistant.components.automation.shellies_announce_gen2] Shellies Announce Gen2: Repeat at step 1: Running automation actions
2023-10-29 10:24:57.322 INFO (MainThread) [homeassistant.components.automation.shellies_announce_gen2] Shellies Announce Gen2: Repeat at step 1: Executing step call service
Iâm now a bit lost. No device are detect in the HA MQTT integration and I donât know what could I check to see whatâs wrong in my setup. What could I do ?
Thank you in advance for any help !
PS : sorry for posting this message in the wrong topic the first time
