I don’t know. Show me your MQTT broker, script and Shelly configuration.
Thanks for your help Maciek, hope this info will help
log form MQTT
Log
[16:25:01] INFO: Setup mosquitto configuration
[16:25:01] WARNING: SSL not enabled - No valid certs found!
[16:25:01] INFO: No local user available
[16:25:01] INFO: Initialize Hass.io Add-on services
[16:25:02] INFO: Initialize Home Assistant discovery
[16:25:02] INFO: Start Mosquitto daemon
1570717502: mosquitto version 1.6.3 starting
1570717502: Config loaded from /etc/mosquitto.conf.
1570717502: Loading plugin: /usr/share/mosquitto/auth-plug.so
1570717502: |-- *** auth-plug: startup
1570717502: ├── Username/password checking enabled.
1570717502: ├── TLS-PSK checking enabled.
1570717502: └── Extended authentication not enabled.
1570717502: Opening ipv4 listen socket on port 1883.
1570717502: Opening ipv6 listen socket on port 1883.
1570717502: Opening websockets listen socket on port 1884.
1570717502: Warning: Mosquitto should not be run as root/administrator.
1570717556: New connection from 172.30.32.1 on port 1883.
[INFO] found homeassistant on local database
1570717556: New client connected from 172.30.32.1 as auto-077A18D0-B00C-3583-4B3B-A3122E477AD9 (p2, c1, k60, u’homeassistant’).
1570719333: Saving in-memory database to /data/mosquitto.db.
1570719556: Client auto-077A18D0-B00C-3583-4B3B-A3122E477AD9 disconnected.
1570719575: New connection from 172.30.32.1 on port 1883.
1570719575: New client connected from 172.30.32.1 as auto-95D77C08-7F1D-FB1F-34BA-04996D298800 (p2, c1, k60, u’homeassistant’).
from /config/automations.yaml (identical to your spec’s)
alias: ‘Shellies Announce’
trigger:- platform: homeassistant
event: start
service: mqtt.publish
topic: shellies/command
payload: announce
alias: ‘Shellies Discovery’
trigger:- platform: mqtt
topic: shellies/announce
service: python_script.shellies_discovery
data_template:
id: ‘{{ trigger.payload_json.id }}’
mac: ‘{{ trigger.payload_json.mac }}’
fw_ver: ‘{{ trigger.payload_json.fw_ver }}’
- platform: mqtt
from /config/configuration.yaml
python_script:
in /config/python_scripts a copie off shellies_discovery.py
Is Shelly’s topic configuration default? What is your discovery_prefix
in MQTT broker configuration?
from MQTT Mosquitto broker addon
“logins”: [],
“anonymous”: true,
“customize”: {
“active”: false,
“folder”: “mosquitto”
“certfile”: “fullchain.pem”,
“keyfile”: “privkey.pem”,
“require_certificate”: false
can you tell me where tot find the Shelly topic configuration
On device website: http://ip_address/
Do you mean the ip address of the shelly device. Yes that is default … it works okay (switch on/off a lamp I have configured for testing) with the Shelly app on my tablet. And I can see the device when check the connected devices on the router.
Announce and discovery automations are enabled in HA?
Show me mqtt topics log after run announce automation.
de logging van MQTT broker - after clicking announce en discovery automations a few time logging is
Log
1570728338: Saving in-memory database to /data/mosquitto.db. 1570730139: Saving in-memory database to /data/mosquitto.db. 1570731940: Saving in-memory database to /data/mosquitto.db. 1570733741: Saving in-memory database to /data/mosquitto.db. 1570735542: Saving in-memory database to /data/mosquitto.db.
or is there another place to check for logging info?
You need mosquitto_sub or MQTT Explorer to make topics log.
Good news! problem solved!!!
after re-checking the shelly device by IP address (idea Maciek; thanks for that!) I noticed that under advance developer settings the option “enable action execution via MQTT” was not checked. After checking this and starting discovery / announce on HASSIO, switch was known as integration / Mosquitto broker.
THANKS MACIEK!!
If anyone using Shelly RGBW2 can tests this version of the script? Mostly light effects.
New version: 0.12.4
Changelog:
- change names of effects for Shelly RGBW2
Hi @Bieniu,
Nice work. I do have a Shelly RGBW2 among other Shelly devices and I followed your script evolution over time.
Good addition for effect names instead of numbers, however I would like to inform you that Shelly documentation is a little bit inacurate (not a surprise ) regarding the available effects for Shelly RGBW2. On the device’s web interface we only have Off
, Meteor Shower
, Gradual Change
and Flash
(in this order).
Using your script makes the led string behave like Meteor Shower
for the rest of the effects, including script’s Flash
effect.
Therefore, for the script version 0.12.4, I propose to change line 759 from
'"fx_list":["Off", "Meteor Shower", "Gradual Change", "Breath", "Flash", "On/Off Gradual", "Red/Green Change"],'
to
'"fx_list":["Off", "Meteor Shower", "Gradual Change", "Flash"],'
and line 768 from
'"fx_tpl":"{% if value_json.effect == 1 %}Meteor Shower{% elif value_json.effect == 2 %}Gradual Change{% elif value_json.effect == 3 %}Breath{% elif value_json.effect == 4 %}Flash{% elif value_json.effect == 5 %}On/Off Gradual{% elif value_json.effect == 6 %}Red/Green Change{% else %}Off{% endif %}",'
to
'"fx_tpl":"{% if value_json.effect == 1 %}Meteor Shower{% elif value_json.effect == 2 %}Gradual Change{% elif value_json.effect == 3 %}Flash{% else %}Off{% endif %}",'
For the same Shelly RGBW2 I also successfully use a separate MQTT sensor for power consumption and I think it would be nice to have it included in your script (much like overpower). I would do it myself but I’m a verry beginer regarding Python language.
Could you show me MQTT topic for power consumption sensor?
Sure.
- platform: mqtt
name: Bed RGB String Power
unique_id: shellyrgbw2-5A3A8A-power
device_class: power
icon: mdi:gauge
state_topic: shellies/shellyrgbw2-5A3A8A/color/0/status
unit_of_measurement: 'W'
value_template: "{{ value_json.power }}"
See also this post in this thread:
Notice the parameter "power": 0
? When I turn on the light this value changes to whatever the instant power consumption is. It increases if I increase the brightness and decreases if I decrease the brightness. It seems to update itself (my sensor) on a ~ 5 seconds delay interval.
Shelly Cloud did not took this into consideration when they report back the consumption history on their Android App (if you enable cloud, of course).
And I just noticed: in white mode you get power consumption reported for each of the white bulbs.
New version: 0.12.5
Changelog:
- remove unused light effects for RGBW2
- add power sensor for RGBW2
Thank you @Bieniu for your super fast fix.
I’ve tested the new version of shelly_discovery script and now I have the new power sensor in place.
Here’s what I did:
I have last version of Home Assistant (0.100.2) installed on a Raspberry Pi 3B with the following add-ons: Samba, SSH, Mosquitto broker (I know it’s deprecated) and HACS. I’ve made a snapshot here so it won’t be necessary to reinstall everything.
I have a Shelly RGBW2 and a RGB led string connected to it. Shelly was configured as White and the shelly_discovery.yaml
automation script in auto mode (without specifying the shelly type as in shellyrgbw2-AABB22: 'white'
At this point, shelly_discovery script registered my device as one light, one overpower sensor and one power sensor.
I restored the snapshot and tried again but this time I added shellyrgbw2-AABB22: 'white'
to the shelly_discovery.yaml
automation script prior to the instalation of shelly_discovery script. Now it worked like a charm.
The bottom line is: we need to specify the shelly type in automation script prior to installation. Or maybe you can tune the discovery part of shelly_discovery script.
Thank you for your great work.
As a side note:
Although I have a RGB strip connected to a Shelly RGBW2, as I mentioned above, when I switch to White mode in their web interface I get power consumption on the fourth channel as well if I turn that channel on (remember: nothing connected to this channel). Weird or what. But this I will take it to the Shelly developers to sort it out.
You don’t have to make snapshots. When will you add shellyrgbw2-AABB22: 'white'
parameter the script will remove from MQTT broker config topics for color entities. After restart HA these entities dissapear from Integrations.
The value of mode
in status
topic is changing to white
when you change to “White mode”?
Could you show me status topic and its payload when you have enabled “White mode”?
If someone wants to help put pressure on Shelly developers to update the documentation this is the right place
