Thank you for this, I’m hoping it will help me, but I’m falling at the first hurdle. When I add the repository I get an error.
If I paste that into a browser I am taken to GitHub.
Why are you trying to add Shellies Discovery
as a custom repository? It is a default repository: https://hacs.xyz/docs/default_repositories#python-scripts
Because Shellies Discovery is not an integration.
I found my error, as I search all of HACS but found nothing.
Shellies Discovery is a python script. Do you have python_script
component enabled in the HA configuration?
That’s what I’ve just enabled. Added the entry to configuration.yaml and created the folder.
Only seeing this is HACS.
It’s there now, that box was already checked. I had to reboot HA twice after enabling the python_scripts. Thanks.
I’m sorry for all the questions, but I’m new to MQTT and I can’t seem to get this to work. I must be doing something wrong.
Where do the devices appear when they get discovered?
Configuration -> Integrations -> MQTT
That’s what I thought. Nothing…
How can I help you without any information?
Have you tried this? https://github.com/bieniu/ha-shellies-discovery#troubleshooting-checklist
What do you need to know? I have checked the troubleshooting. I think everything is correct.
I added those but cannot see any entries.
logger:
default: info
logs:
pydeconz: debug
homeassistant.components.deconz: debug
pyShelly: debug
homeassistant.components.python_script: debug
homeassistant.components.automation: info
python_script:
extract from my config.yaml
Shelly config (testing a single Shelly 2.5).
firmware
home assistant version
After restarting HA you should have information about announce
in the log. I you don’t have it, than you don’t have the automations installed correctly.
Ok. But I don’t know what I have done wrong. I added python_script to config yaml, rebooted twice and then installed your script from HACS.
I’ve then added the logger entries and rebooted again (several times).
@Puntoboy first you have to check if your MQTT broker and MQTT integration in Home Assistant works fine. Then you have to install the Shellies Discovery Script automations correctly. You said that you are new with MQTT. Maybe your MQTT broker is not working correctly?
