Does anyone know if we are supposed to get a working power metering when powering Shelly 1PM or 2.5 on 24VDC instead of usual 110 or 230VAC ?
I have about 10 Shelly 1PM and 2.5 working fine on 230VAC. I need to add 2 on 24VDC. They work fine but never update the power usage of the relays. Is this a hardware limitation due to how DC current work ? or a software limitation ?
Hi, I suspect that this may be a limitation in the way that power measurments are derived using CT’s (Current Transformers). These use a coil and magnetic core around the main conductor to induce a signal that is proportional to the AC current that is flowing which is proportional to the power. It will not work properly for DC circuits.
If your load is fairly constant then you can approximate the power usage by integrating this constant value while the switch is on e.g. if you had a 1kW load switched on for half and hour than the power used would be 0.5kWh.
