hi @ashscott and hi @woody4165
I wanted to do the same thing:
I have this code
alias: ‘Imposta Posizione Tapparella’
platform: state
entity_id: input_number.slider_tapparella
delay: ‘00:00:3’
service: mqtt.publish
data_template:
topic: ‘shellies/shellyswitch-xxxxxx/roller/0/command/pos’
retain: true
payload: “{{ states(‘input_number.slider_tapparella’) | int }}”
input_number:
slider_tapparella:
name: Posizione Tapparella
min: 0
max: 100
step: 1
and so I see the slider correctly in the group but if I open the shutter from the button or from within the entity, the slider remains with the old value. How can I update the value of the slider in the group when I open or close the shutter with other functions?
ashscott
(Ash)
January 23, 2019, 3:15pm
43
I understand what you want to do but I haven’t implemented that yet.
You need to get the position that the Shelly thinks it’s at from:
position_topic: “shellies/shellyswitch-xxxxxx/roller/0/pos”
And then set your input_number to that value.
Should be fairly straightforward, I’d have thought, but I’ve not looked into it myself, yet.
in fact, I also think it should not be complicated. The function is the one that told you, only I do not know how to implement it
Do I have to do an automatism?
If so what trigger should I do?
woody4165
(Woody)
January 24, 2019, 10:52am
45
If you change to Lovelace, you can have it easily…
yes, I read that you used it. But now I am already learning to use Hasso, I would not complicate myself too much with another Interface.
woody4165
(Woody)
January 24, 2019, 11:19am
47
So, do not upgrade to 0.86 because from this release Lovelace will become the standard UI.
Just saw, that it’s still possible to have previous UI at my-ip:8123/states
Lovelace just became the standard UI, so after upgrade you will be redirected to Lovelace
ashscott
(Ash)
January 24, 2019, 11:39am
48
I think you need something like this:
automation:
- alias: Set position slider
platform: mqtt
topic: 'shellies/shellyswitch-xxxxxx/roller/0/pos'
service: input_number.set_value
data_template:
entity_id: input_number.position_slider
value: "{{ trigger.payload }}"
I think that the slider should then follow the position the Shelly thinks it is at.
I’ve not tried it!
GREAT !! it works perfectly !
I just had to change “input_number.position_slider” with “input_number.slider_tapparella”
Thank you so much!
Just a question. I had written the following code, but it did not work. Wrong something?
alias: ‘Aggiorna Slider Tapparella’
platform: state
entity_id: cover.tapparella_salone
service: input_slider.select_value
data_template:
entity_id: input_slider.slider_tapparella
value: “shellies/shellyswitch-XXXXX/roller/0/pos”
woody4165:
Oops, I upgraded about an hour ago !!!
I noticed some graphic improvement, but it works all the same way, maybe …
ashscott
(Ash)
January 24, 2019, 10:24pm
51
It’s hard to tell without the proper formatting and indentation.
You’re also missing some brackets.
See the top of the page and format the code.
OK thanks. but so it is only badly formatted, but conceptually could it work?
In any case, your solution works great! I’m very happy !
woody4165
(Woody)
January 25, 2019, 6:08am
53
When you write a piece of code in this forum, mark it and use </> to have it correctly formatted!
ClaRod
January 25, 2019, 9:45pm
54
Hello!
I installed my first Shelly 2 device as a roller shutter switch today. Everything works fine but there’s something I don’t understand.
First, this is my setup:
**covers.yaml:**
# Essbereich rechts
- platform: mqtt
name: "Jalousie Essbereich rechts"
icon: mdi:window-open
state_topic: "shellies/shellyswitch-XXXXXX/roller/0"
command_topic: "shellies/shellyswitch-XXXXXX/roller/0/command"
position_topic: "shellies/shellyswitch-XXXXXX/roller/0/pos"
set_position_topic: "shellies/shellyswitch-XXXXXX/roller/0/command/pos"
payload_open: "open"
payload_close: "close"
payload_stop: "stop"
retain: false
optimistic: false
qos: 1
position_open: 100
position_closed: 0
**automation.yaml:**
- id: two
alias: Slider verschoben rechts
platform: mqtt
topic: 'shellies/shellyswitch-XXXXXX/roller/0/pos'
data_template:
entity_id: input_number.shutter1
- id: three
alias: Slider verschieben rechts
platform: state
data_template:
topic: 'shellies/shellyswitch-XXXXXX/roller/0/command/pos'
retain: true
payload: "{{ states('input_number.shutter1') | int }}"
Everything, even the slider with percentage, works fine but in my log the alias “Slider verschoben rechts” is triggered once or twice a minute and I don’t know why.
Does anyone see my mistake?
I tried but I can not. It is formatted badly.
I write <code </> but it is badly formatted.
Am I wrong? Can you give me an example?
Hi @ashscott
your code is great, but it create a lot of log !!!
ashscott:
automation:
platform: mqtt
topic: ‘shellies/shellyswitch-xxxxxx/roller/0/pos’
data_template:
value: “{{ trigger.payload }}”
So I made some changes and I modified the code as follows:
- alias: 'Aggiorna Posizione Slider Tapparella'
- platform: state
- service: input_number.set_value
data_template:
value: '{{ states.cover.tapparella_salone.attributes.current_position }}'
Ad It Works Well and do not reate a lot of log !!
hi @ClaRod
I’m not an expert on home assistants, I’m actually a beginner, but I think the problem is the automatism that updates the slider with MQTT.
I also had a lot of logs. I solved by performing the update as I wrote in the previous answer!
I think you can modify my code simply.
woody4165
(Woody)
January 26, 2019, 8:43am
58
You have to mark the code, then click on the button </> that is greyed out in the gif anumation and that’s it
ClaRod
January 26, 2019, 3:25pm
59
Hi @destroyer76 .
I modified your code and it works fine! Thank you for your fast and good work
Thanks a lot @woody4165 !!!
It was a very simple thing! But I had not really noticed it! I’m embarassed
You look very experienced. I’m a programmer but sometimes I went crazy for the simplest things. The documentation of Homa Assistant sometimes is not complete, and I found only in the forums some syntax.
Is there any guide, possibly in Italian, that I can use to study the syntax?
Hi @ClaRod
it was a pleasure. I’m happy to help you
