Shelly 2 as roller shutter with percentage
You have them both with the same name.
awning_position is the name I gave it. You can name yours anything you like but they must be different from each other.
input_number:
  awning_position:
    icon: mdi:map-marker-distance
    initial: 0
    min: 0
    max: 100
    step: 10
#Estore slider
  awning_position_1:
    name: Awning Position 1
    initial: 0
    min: 0
    max: 100
    step: 10
You need the indentation.
apparently it will workā€¦ if all ok i will post full instructions for other users ok?
Glad you got it sorted.
What instructions was I missing?
hi thereā€¦well it does not work
automation is:
  • alias: ā€˜PosiĆ§Ć£o estore Suiteā€™
    initial_state: ā€˜onā€™
    • platform: state
      entity_id: input_number.awning_position_suite
    - delay: ā€˜00:00:3ā€™
    • service: mqtt.publish
      data_template:
      topic: ā€˜shellies/shellyswitch25-73C369/roller/0/command/posā€™
      retain: true
      payload: ā€œ{{ states(ā€˜input_number.awning_position_suiteā€™) | int }}ā€
and configuration yaml is:
input_number:
awning_position_suite:
name: Posicao estore suite
initial: 0
min: 0
max: 100
step: 10
#Estore slider
posica_estore_suite:
initial: 0
min: 0
max: 100
step: 10
what am i doing wrong?
You need to format you code for it to be read correctly:
- alias: 'Set awning position'
  initial_state: 'on'
    - platform: state
    # - delay: '00:00:3'
    - service: mqtt.publish
      data_template:
        topic: 'shellies/shellyswitch-559C7E/roller/0/command/pos'
        retain: true
        payload: "{{ states('input_number.awning_position') | int }}"
You have no indentation, thatā€™s the first place to start.
If you format the code so it displays correctly itā€™ll be easier to help you.
Screen2019-04-22_10-43-59_am
Do you mean it doesnā€™t do what you expect or itā€™s doesnā€™t pass config check?
Does it display in the front end?
hi
so it passes the config and can add the slider on the UI
config:
  input_number:
  awning_position:
    initial: 0
    min: 0
    max: 100
    step: 10
#Estore slider
    initial: 0
    min: 0
    max: 100
    step: 10
automation file yaml:
  initial_state: 'on'
    - platform: state
      data_template:
        retain: true
thanks
You need to format all of the code.
Indentation is not correct for the input_number:
Everything below input_number needs to move right.
Or input_number needs to move left. Itā€™s difficult to tell with the formatting as is.
Thatā€™s better. Move the input_number left.
When you say itā€™s not working, what is happening?
input_number:
  awning_position:
    initial: 0
    min: 0
    max: 100
    step: 10
All that should happen is when you click on the slider line the cover will move to that position. The indicator doesnā€™t move with the cover, just in case thatā€™s what you were expecting.
Hi
what happens is this:
Image from the slider
image from built in code:
so it seams that they are not synced
since i am not at home now i dont know if the roller is really moving or not but i think not
  initial_state: 'on'
    - platform: state
      data_template:
        retain: true
config:
input_number:
awning_position:
initial: 0
min: 0
max: 100
step: 10
    #Estore slider
      posicao_estore_suite:
        initial: 0
        min: 0
        max: 100
        step: 10
the entity i am adding is this one:
Iā€™m not sure what you are trying to achieve but if you add a sensor you will be able to see what position the awning is.
  - platform: mqtt
    name: "Awning Position"
    state_topic: "shellies/shellyswitch-Ā£Ā£Ā£Ā£Ā£Ā£/roller/0/pos"
    unit_of_measurement: "%"
    icon: mdi:percent
ok will try this night and give feedback !
hi againā€¦
i am so sorry for beeing a noob . you are helping a lot
so with the sensor i got the following:
but this is the result of changing this slider:
and not this one
that apparently is not getting the info to send to shelly :frowning:
current code:
config:
  input_number:
  awning_position:
    initial: 0
    min: 0
    max: 100
    step: 10
#Estore slider
    initial: 0
    min: 0
    max: 100
    step: 10
automation yaml:
  initial_state: 'on'
    - platform: state
      data_template:
        retain: true
input_number is still indented incorrectly. Move it left.
correct?
Yes. Thatā€™s it.
done but it does not workā€¦
apparently the slider does not send info i thinkā€¦
the sensor gives the correct info about the state but the slider, no matter where i move it does not impact the sensor
The sensor is getting itā€™s information from the Shelly so the Shelly must be responding to the slider.
