Yes, please. That would be awesome.
Has somebody testet this with Shelly 1 Plus, or something other devices, from the PLUS-Series?
I tested with shelly 4pm.
seems like 4pm does send single_push instead of single
changed the code like this
blueprint:
name: Shelly switch events
description: Control anything from shelly SW
domain: automation
input:
remote:
description: Button to use
selector:
device:
integration: shelly
multiple: false
channel:
description: Which shelly channel should trigger this automation
default: 1
selector:
number:
min: 0.0
max: 20.0
mode: box
step: 1.0
button_single:
default: []
selector:
action: {}
button_double:
default: []
selector:
action: {}
button_triple:
default: []
selector:
action: {}
button_long:
default: []
selector:
action: {}
button_single_long:
name: Button single long
default: []
selector:
action: {}
button_long_single:
name: Button long single
default: []
selector:
action: {}
source_url: https://community.home-assistant.io/t/shelly-device-switch-template-for-each-click-type/296528/10
mode: restart
max_exceeded: silent
- platform: event
event_type: shelly.click
event_data:
device_id: !input remote
channel: !input channel
- variables:
event: '{{ trigger.event.data.click_type }}'
- choose:
- conditions:
or:
- '{{ event == "single" }}'
- '{{ event == "single_push" }}'
sequence: !input button_single
- conditions:
or:
- '{{ event == "double" }}'
- '{{ event == "double_push" }}'
sequence: !input button_double
- conditions:
- '{{ event == "triple" }}'
sequence: !input button_triple
- conditions:
or:
- '{{ event == "long" }}'
- '{{ event == "long_push" }}'
sequence: !input button_long
- conditions:
- '{{ event == "single_long" }}'
sequence: !input button_single_long
- conditions:
- '{{ event == "long_single" }}'
sequence: !input button_long_single
I’ve tested it with Shelly 1 Plus and changed the blueprint to this:
blueprint:
name: Shelly Push events
domain: automation
input:
remote:
selector:
device:
integration: shelly
channel:
default: 1
selector:
number:
min: 0
max: 20
mode: box
button_single:
default: []
selector:
action: {}
button_double:
default: []
selector:
action: {}
button_triple:
default: []
selector:
action: {}
button_long:
default: []
selector:
action: {}
button_single_long:
default: []
selector:
action: {}
button_long_single:
default: []
selector:
action: {}
mode: restart
- platform: event
event_data:
device_id: !input 'remote'
channel: !input 'channel'
- variables:
- choose:
- conditions:
sequence: !input 'button_single'
- conditions:
sequence: !input 'button_double'
- conditions:
sequence: !input 'button_triple'
- conditions:
sequence: !input 'button_long'
- conditions:
sequence: !input 'button_single_long'
- conditions:
sequence: !input 'button_long_single'
I have only change “click” to “push” and it works for single, double and long. Tripple and singe_long and long_single doesn´t work in my test. For tests, i have connect a switch, but not found a solution for the other 3 states.
What are the differents between long_push, single_long and long single?
How I can test it, if this is working?
Can I change the transition time between the triggers of the button?
Do you have additional tips for me?
Greetings from Germany
Generation 2 devices (The Shelly Plus ones) use the values btn_down
, btn_up
, single_push
, double_push
, triple_push
and long_push
as click_type
according to Shelly - Home Assistant
That would be why those others doesn’t work.
I got the button to toggle my zigbee led panels on and off. Now how do I make so that holding the button in will dim my zigbee panel up and down in an infinite loop? So as long as I hold the button in it will dim up and down until released?
thanks for the blueprint, however I dont get it working.
After I switched on the entity “input” I was able to see changes when switching my switch:
This is one cycle of switching on and off once.
only switching on seems to have the “long press” input switching off just gives a “Energy Erkannt”.
Mapping the “long press” to a szene works but none of the others do, I think its because switching off is not recognized the same way if this makes sence.
Some more Info:
Can somebody help me understand wha I am doing wrong?
