I just added a second i4 and tried to use the blueprint again. Worked fine for the first i4 a few weeks ago. Second one couldnt be found by the blueprint. Similar to issue reported above.
I deleted the follow lines out of the top of the blueprint and tried again. This time it showed all my shelly devices and I could successfully choose the new i4.
model: SNSN-0024X
multiple: false
âIf your model is not shown in the dropdownlist, remove the line under input â model: SNSN-0024Xâ
When I start the Blueprint âShelly i4 4 Buttons actionsâ, Home Assistant shows no device in the dropdown, I think, I have to remove the model.
But where is it?
In YAML Code, there is only:
description: ââ
alias: Shelly i4 4 Buttons actions
use_blueprint:
path: Danieldz/shelly-i4-4-buttons-actions.yaml
you need to edit it in config file under blueprints-danieldz. I use addon studio code server.
I got the i4 partly working. Single short press works, but double short press and long press doesnt work.
In the webinterface of the i4, I have set input mode to âButtoonâ for all 4 inputs.
In Home Assistant, I have the this automation:
Single click works, doubleclick does NOT.
Here is the YAML:
What is missing?
alias: i4_192_Blueprint
description: ""
use_blueprint:
input:
button: 123xyz...
singleb1:
- metadata: {}
data: {}
entity_id: light.191_dimmer_wc
action: light.toggle
doubleb1:
- action: light.turn_on
metadata: {}
brightness_pct: 20
longb1: []
If anyone wants to try a Shelly i4 blueprint with more featuresâŚ
