diramu
(Mark)
October 18, 2022, 5:47am
42
When esphome-flasher reads the cpu in my shelly plus 1,
Chip Info:
Chip Family: ESP32
Chip Model: unknown ESP32 (revision 3)
Number of Cores: 1
Max CPU Frequency: 80MHz
Has Bluetooth: YES
Has Embedded Flash: YES
Has Factory-Calibrated ADC: YES
80MHz not 160MHz, I assume I need to change cpu freq in the setup, or leave default?
sender
November 2, 2022, 8:18pm
43
For what it may help this works for me:
#https://github.com/esphome-devices/esphome-devices/issues/299
#https://www.esphome-devices.com/devices/Shelly-Plus-1PM
substitutions:
device_name: "shelly-plus-1pm-01"
# Higher value gives lower watt readout
current_res: "0.001"
# Lower value gives lower voltage readout
voltage_div: "2050"
#was 1925
esphome:
platformio_options:
board_build.f_cpu: 160000000L
esp32:
board: esp32dev
framework:
type: esp-idf
version: latest
sdkconfig_options:
CONFIG_FREERTOS_UNICORE: y
CONFIG_ESP32_DEFAULT_CPU_FREQ_160: y
CONFIG_ESP32_DEFAULT_CPU_FREQ_MHZ: "160"
CONFIG_ESP_TASK_WDT_TIMEOUT_S: "20"
CONFIG_BT_BLE_50_FEATURES_SUPPORTED: n
CONFIG_BT_BLE_42_FEATURES_SUPPORTED: y
wifi:
ssid: "IOTDOM"
password: !secret wifi_key
domain: !secret domain
#use_address: 192.168.6.77
ap:
ssid: "${device_name} Fallb Hotspot"
password: !secret Fallback_Hotspot
logger:
api:
ota:
esp32_ble_tracker:
scan_parameters:
active: false
bluetooth_proxy:
button:
- platform: safe_mode
time:
- platform: homeassistant
output:
- platform: gpio
pin: GPIO26
switch:
- platform: output
output: "relay_output"
binary_sensor:
- platform: gpio
pin: GPIO4
on_press:
then:
- switch.toggle: "relay"
filters:
- delayed_on_off: 50ms
- platform: gpio
pin:
number: GPIO25
inverted: yes
mode:
input: true
pullup: true
on_press:
then:
filters:
- delayed_on_off: 5ms
- platform: ntc
sensor: temp_resistance_reading
name: "${device_name} Temperature"
unit_of_measurement: "°C"
accuracy_decimals: 1
icon: "mdi:thermometer"
calibration:
b_constant: 3350
reference_resistance: 10kOhm
reference_temperature: 298.15K
on_value_range:
- above: "80.0"
then:
- switch.turn_off: "relay"
- platform: resistance
sensor: temp_analog_reading
configuration: DOWNSTREAM
resistor: 10kOhm
- platform: adc
pin: GPIO32
attenuation: 11db
- platform: adc
name: "${device_name} Relay Supply Voltage"
pin: GPIO33
attenuation: 11db
filters:
- multiply: 8
- platform: hlw8012
model: BL0937
sel_pin:
number: GPIO23
inverted: true
cf_pin: GPIO5
cf1_pin: GPIO18
current_resistor: ${current_res}
voltage_divider: ${voltage_div}
current:
unit_of_measurement: A
accuracy_decimals: 3
icon: mdi:flash-outline
voltage:
unit_of_measurement: V
power:
unit_of_measurement: W
on_value_range:
- above: "3600"
then:
change_mode_every: 2
update_interval: 10s
- platform: total_daily_energy
name: "${device_name} Daily energy consumed"
power_id: power
filters:
- multiply: 0.001
unit_of_measurement: kWh
icon: mdi:clock-alert
status_led:
pin:
number: GPIO0
inverted: true
sender
November 12, 2022, 1:18pm
44
Hi there, is there any one having luck with flashing a Shelly plus i4 with esphome?
I have done:
and this pin layout:
similar to this:
Where I have connected pin3 to 4 and 2 to 1.
This gives me output on the serial (so it must be connected ok and in flash mode) but I am not able to successfully flash.
the error:
Using 'COM6' as serial port.
Connecting........_
Detecting chip type... ESP32
Connecting...
Chip Info:
- Chip Family: ESP32
- Chip Model: unknown ESP32 (revision 3)
- Number of Cores: 1
- Max CPU Frequency: 80MHz
- Has Bluetooth: YES
- Has Embedded Flash: YES
- Has Factory-Calibrated ADC: YES
- MAC Address: 08:3A:F2:00:AA:68
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
- Flash Size: 4MB
- Flash Mode: dio
- Flash Frequency: 40MHz
Erasing flash (this may take a while)...
Unexpected error: Error while erasing flash: Timed out waiting for packet content
sender
November 20, 2022, 7:13pm
45
I have to get back… it works for a little while.
After placing it in the wall, booting it up the wifi wprks for a limited amount of time.
Locally it keeps working a while…
Then after a while also no local control possible anymore.
Practically impossible to track the serial logging…
Bummer.
gureyes
(Gary)
April 29, 2023, 2:52am
46
Has anyone been successful in getting active Bluetooth connections?
Is it even possible?
