I’m having issue with Shelly integration with this Shelly Plus H&T device that it shows Unknown all the time for all entities. Other devices that I have there was option to enable ColoT which works fine.
Any tips or should I move to MQTT?
I have two sensor one is with beta firmware: 0.12.0-beta1 and one with stable 0.11.4.
Home assistant version: Home Assistant 2022.11.2
Testing after configuring web socket for shelly H&T Plus, lets see if we get better results.
Added ws://homeassistantipaddress:8123/api/shelly/ws into Shelly H&T settings
I completely removed those shelly H&T sensors from homeassistant shelly integration and updated sensors to beta firmware.
Enabled web sockets on both to hommeassistant(checked also from top right icon that it’s connected).
Then I added them from Integrations view as normally adding new device to integration and now it LOOKS like it’s working again as it should, I have no idea should this have any affect on it or not but it’s working.
EDIT: Just note that it took a while for them to show any values, patience is required.
I have an issue with H&T Plus too. I tried with both stable and beta versions, I connected the WebSocket, and it’s working, I added the integration in HA but I cannot see the device, nor the entities. I did reset it to factory defaults and tried again with the same outcome.
I am on Home Assistant 2022.11.2.
Any idea?
I have 2022.11.2 should work completely normal as long as you are in same VLAN and have done the steps I did. No issues here from the solution of mine I tagged.
Any News or Ideas on this? I also can add the device to HA and it tells me it adds the integration, but there’s no device and no entities showing up like @solomalee also experienced.
Any help would be appreciated.
