Show off your picture-elements uses
i used esphome on d1 mini here is the yaml
esphome:
  platform: ESP8266
  board: d1_mini
wifi:
  ssid: "SSID"
  password: "Your Password"
  # Optional manual IP
  manual_ip:
    static_ip: 192.168.1.11
    gateway: 192.168.1.1
    subnet: 255.255.255.0
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
switch:
#lock pin GPIO
- platform: gpio
  pin: D1
#Unlock pin GPIO
- platform: gpio
  pin: D2
#Engine pin GPIO
- platform: gpio
  pin: D5
#start engine
  optimistic: true
  turn_on_action:
  - switch.turn_on: lock_btn
  - delay: 800ms
  - switch.turn_off: lock_btn
  - delay: 400ms
  - switch.turn_on: engine_btn
  - delay: 4000ms
  - switch.turn_off: engine_btn
  - switch.turn_off: start_engine
#stop engine
  optimistic: true
  turn_on_action:
  - delay: 4000ms
  - switch.turn_off: stop_engine
#Lock Car
  optimistic: true
  turn_on_action:
  - delay: 500ms
  - delay: 500ms
  - delay: 500ms
  - switch.turn_off: lock_car
#Unlock Car
  optimistic: true
  turn_on_action:
  - switch.turn_on: unlock_btn
  - delay: 500ms
  - switch.turn_off: unlock_btn
  - switch.turn_off: unlock_car
4066 ic is kind of relay for small components check below image how i connected ic with d1 mini and keyfob.
svg
here is a video tutorial on how to use 4066
let me know if you need anymore help. i’m happy to help
Thank you.
This is great! How did you create the buttons to toggle between downstairs and upstairs? Can you share your yaml?
I used an input select with a service-call button. See the heading Creating a Floor Toggle in this post: https://aarongodfrey.dev/home%20automation/creating-a-3d-floorplan-in-home-assistant/
That’s pretty cool! I just have one favor to ask. Could you please do me a favor with the proper spacing and tabs? I’m having some difficulty figuring out the syntax in yaml.
Thanks!
elements:
  - entity: sensor.living_room
    state_image:
      Netflix: /local/pictures/netflix.png
      PowerOff: /local/pictures/harmony-remote.png
      Watch TV: /local/pictures/kodi.png
      xbox: /local/pictures/xbox-one.png
    style:
      left: 50%
      top: 50%
      width: 100%
    tap_action:
      action: none
    type: image
  - icon: 'mdi:xbox'
    style:
      color: '#FFFFFF'
      left: 5%
      top: 87%
    tap_action:
      action: call-service
      entity_id: remote.living_room
      service: REMOTE.TURN_ON
      service_data:
        activity: xbox
    title: Xbox one
    type: icon
  - icon: 'mdi:netflix'
    style:
      color: '#FFFFFF'
      left: 13%
      top: 87%
    tap_action:
      service_data:
        activity: Netflix
    title: Xbox one
    type: icon
  - icon: 'mdi:kodi'
    style:
      color: '#FFFFFF'
      left: 21%
      top: 87%
    tap_action:
      service_data:
        activity: Watch TV
    title: Xbox one
    type: icon
  - entity: remote.living_room
    service: REMOTE.TURN_OFF
    style:
      color: '#FFFFFF'
      left: 87%
      top: 87%
    title: Turn All Off
    type: service-button
image: /local/pictures/harmony-remote.png
style: null
type: picture-elements
[quote="omerome, post:65, topic:63642, full:true"]
That's pretty cool! I just have one favor to ask. Could you please do me a favor with the proper spacing and tabs? I'm having some difficulty figuring out the syntax in yaml.
Thanks!
[/quote]
Hi sorry that was one of my first times posting here till i read about posting code.
hope it helps you! i can aslo send u the pictures if you like
Thanks again! Sure, if you can send the pictures, that would be great!
So I had just finished modeling my floor plan and integrating into lovelace using picture-elements. The thing I like about my approach is that the lights are not confined to a picture edge and they bleed and blend together. I’m still playing around with it but will most likely show a demonstration on YouTube at sometime.
This is looking very good !
What software did you use to do the 3D modeling ? I’m currently doing it with HomeByMe but not fully satisfied with it…
I started with Sweet Home 3D then found it lacking after I did the layout, so I imported into 3Dmax and do the rest in there. I would suggest to do the plan layout in a software like sweet home 3d as 3D max is a bit more involved when it comes to plan layouts.
Starting with mcfrojd and his original setup, I created this modified look to provide info for my wife and I, combining life360 and Places. Using the config-template-card, I added the battery icon color change based on percentage to HSL 0 to 220. Pretty happy with it at this point, but may expand upon it in the future.
customized-picture_element_card_01
customized-picture_element_card_02 customized-picture_element_card_03
Also with looking ahead, here’s my floorplan I’ve started to work on for when I get the time to wall mount a tablet.
haha great! A post like that of course comes with the code… especially the setup of the presence images etc, please share?
Ive made up something like this, with images, background colors and overlays depending on presence/location myself, using buttons and a few backend template sensors, so would love to see if I can learn/borrow/use your techniques.
Im not using a picture-elements card so can’t post here, but did so here with the code a few posts below that.
btw, seem to have read elsewhere how you made these avatars, but cant find it, please tell ?
Sorry, multiple things at work here, so it’s going to be a lengthy post.
First off, you need life360 and places. Then the images, my wife and I use an app called Bitmoji for those, and using the below png template and photoshop I created the different state images. You’ll want to set the circles to your lovelace background color and the rest to your default card color. Put them all in /www/images/person/ so that the Person_Status sensor can reference them.
ha_frame
Then the sensors:
binary_sensors:
  platform: template
    sensors:
      person_moving:
      friendly_name: "Person Moving"
        value_template: >-
          {% if state_attr('device_tracker.life360_person', 'place') == state_attr('device_tracker.life360_person', 'address') %}
            off
          {% elif is_state_attr('device_tracker.life360_person', 'driving', true) %}
            on
          {% elif is_state_attr('device_tracker.life360_person', 'moving', true) %}
            on
          {% else %}
            off
          {% endif %}
sensors:
  platform: template
    sensors:
      person_location:
        friendly_name: "Person Location"
        value_template: >-
            {{ state_attr('device_tracker.life360_person', 'place') }}
          {% elif states.sensor.person.attributes.place_name != "-" %}
              {{ state_attr('sensor.person', 'place_name') }}
          {% else %}
            {% if is_state('binary_sensor.person_moving', 'on') %}
              {% if state_attr('sensor.person', 'street_number') != '-' %}{{ state_attr('sensor.person', 'street_number')}} {% endif %}{% if state_attr('sensor.person', 'street') != '-' %}{{state_attr('sensor.person', 'street')}}{% endif %}{% if state_attr('sensor.person', 'city') != '-' %}, {{state_attr('sensor.person', 'city')}}, {% if state_attr('sensor.person', 'state_province') != '-' %}{{state_attr('sensor.person', 'state_province')}}{% endif %}{% endif %}
            {% else %}
              {{ state_attr('sensor.michael', 'street_number') + " " + state_attr('sensor.michael', 'street')}}
            {% endif %}
          {% endif %}
      person_status:
        friendly_name: "Person Status"
        value_template: >-
          {% if is_state_attr('device_tracker.life360_person', 'driving', true) %}
            Driving near {{ states('sensor.person_location') }}
            Moving near {{ states('sensor.person_location') }}
          {% else %}
          {% endif %}
        entity_picture_template: >-
          {% if state_attr('sensor.person', 'place_type') == 'supermarket' %}
            /local/images/person/grocery.png
          {% elif state_attr('device_tracker.life360_person', 'place') == 'Work' %}
            /local/images/person/work.png
          {% elif state_attr('device_tracker.life360_person', 'place') == 'Home' %}
            /local/images/person/home.png
          {% elif state_attr('device_tracker.life360_person', 'driving') == true %}
            /local/images/person/driving.png
          {% elif state_attr('device_tracker.life360_person', 'moving') == true %}
            /local/images/person/moving.png
          {%else %} /local/images/person/home.png{%endif%}
      person_at_loc_since:
        friendly_name: "At Location Since"
        value_template: >-
          {% if (as_timestamp(now()) - as_timestamp(states.sensor.person_location.last_changed)) / 3600 < 24 %}
            Since {{ (states.sensor.person_location.last_changed.strftime("%s") | int ) | timestamp_custom("%-I:%M %p") }}
          {% else  %}
            Since {{ (states.sensor.person_location.last_changed.strftime("%s") | int ) | timestamp_custom("%a, %b %-d at %-I:%M %p") }}
          {% endif %}
      person_battery:
        friendly_name: "Battery"
        unit_of_measurement: '%'
        value_template: "{{states.device_tracker.life360_person.attributes.battery }}"
        icon_template: >-
          mdi:battery{% if is_state_attr('device_tracker.life360_person', 'battery_charging', true) %}-charging{% else %}{% endif %}{% if 0<(state_attr('device_tracker.life360_person', 'battery') | float / 10 ) | round(0) * 10 < 100%}-{{ (state_attr('device_tracker.life360_person', 'battery') | float / 10 ) | round(0) * 10 }}{% else %}{% if (state_attr('device_tracker.life360_person', 'battery') | float / 10 ) | round(0) * 10 == 0%}-outline{%else%}{% if is_state_attr('device_tracker.life360_person', 'battery_charging', true) %}-100{% endif %}{% endif %}{% endif %}
      person_wifi:
        friendly_name: "WiFi"
        value_template: >-
          {% if is_state_attr('device_tracker.life360_person', 'wifi_on', true) %}
            on
          {% else %}
            off
          {% endif %}
        icon_template: >-
            mdi:wifi
          {% else %}
            mdi:wifi-off
          {% endif %}
      person_height:
        value_template: >-
            70px
          {% else %}
            40px
          {% endif %}
Then the frontend code:
cards:
  - card:
      cards:
        - elements:
            - entity: '${''device_tracker.life360_'' + vars[0]}'
              image: >-
                "${states['sensor.' + vars[0]
                +'_status'].attributes['entity_picture']}"
              style:
                left: 50%
                top: 50%
                width: 100%
              type: image
            - entity: '${''sensor.'' + vars[0] +''_battery''}'
              style:
                '--paper-item-icon-color': >-
                  ${'hsl(' + (states['sensor.' + vars[0] +'_battery'].state*1.1
                  )*((states['sensor.' + vars[0] +'_battery'].state/100)) +
                  ',90%,40%)'}
                left: 4.5%
                top: 3.5%
                transform: 'scale(1.2,1.2)'
              type: state-icon
            - entity: '${''sensor.'' + vars[0] +''_wifi''}'
              style:
                '--paper-item-icon-color': '#2b9af9'
                left: 80.5%
                top: 3.5%
              type: state-icon
          image: '${''/local/images/'' + vars[0] +''/home.png''}'
          type: 'custom:hui-picture-elements-card'
        - color_type: icon
          entity: '${''sensor.'' + vars[0] +''_status''}'
          show_icon: false
          show_name: false
          show_state: true
          tap_action:
            action: url
            url: '${states[''sensor.'' + vars[0]].attributes[''map_link'']}'
          styles:
            card:
              - height: '${states[''sensor.'' + vars[0] +''_height''].state}'
            state:
              - padding-top: '${vars[2]}'
              - padding-left: 14px
              - padding-right: 14px
              - white-space: '${vars[1]}'
              - text-overflow: '${vars[1]}'
              - word-break: break-word
          type: 'custom:button-card'
        - card:
            color_type: icon
            entity: '${''sensor.'' + vars[0] +''_at_loc_since''}'
            show_icon: false
            show_name: false
            show_state: true
            tap_action:
              action: url
            styles:
              card:
                - height: 30px
              state:
                - padding-bottom: 14px
                - font-size: 12px
          conditions:
            - entity: '${''binary_sensor.'' + vars[0] + ''_moving''}'
              state: 'off'
          type: conditional
      type: 'custom:vertical-stack-in-card'
    type: 'custom:config-template-card'
    variables:
      - '''person1'''
        {if (states['sensor.' + vars[0] +'_height'].state ===
        '70px')'unset';else 'nowrap'}
        {if (states['sensor.' + vars[0] +'_height'].state === '70px')'4px';else
        '14px'}
  - card:
      cards:
        - elements:
              image: >-
              style:
                left: 50%
                top: 50%
                width: 100%
              type: image
              style:
                  ',90%,40%)'}
                left: 4.5%
                top: 3.5%
              type: state-icon
              style:
                left: 80.5%
                top: 3.5%
              type: state-icon
        - color_type: icon
          show_icon: false
          show_name: false
          show_state: true
          tap_action:
            action: url
          styles:
            card:
            state:
        - card:
            color_type: icon
            show_icon: false
            show_name: false
            show_state: true
            tap_action:
              action: url
            styles:
              card:
                - height: 30px
              state:
                - font-size: 12px
          conditions:
              state: 'off'
          type: conditional
    variables:
      - '''person2'''
        '14px'}
type: horizontal-stack
Hopefully you can follow all of that. Essentially it’s a horizontal stack with two configurable vertical-stack-in cards where if you’re life360 name and sensors names are all the same the only thing you need to do is drop in your name in the variables: area.
I know there’s probably some cool ways to clean this up or do it better and am open to suggestions. If you have any additional questions feel free to ask.
thanks!
I use life360 and comparable template sensors where I only have to change the name :wink: So understand what you’re saying.
Will study this and thank you again!
A quick one for starters:
I tried using picture-entity before with a sensor that has an image .png for state in the image field, but that doesnt work unfortunately.
How then is this possible:
 - elements:
              image: >-
              style:
                left: 50%
                top: 50%
                width: 100%
              type: image
using a template in the image field?
trying it like this:
  - type: 'custom:vertical-stack-in-card'
    cards:
      - type: 'custom:hui-picture-elements-card'
        image: /local/various/presence_frame.png
        elements:
          - type: image
            entity: '${"device_tracker.life360_name"}'
            image: >-
              ${states['sensor.name_picture].state}
            style:
              left: 50%
              top: 50%
              width: 100%
but it cant find the image.
states[‘sensor.name_picture’].state is the image-file including path so referencing that should work. I suspect the syntax is incorrect, so would truly appreciate some assistance :wink:
got it to this, showing the correct image, and frame, though not fitting at all. Still there’s progress :slight_smile:
  - type: 'custom:config-template-card'
    variables:
      - states['sensor.name_picture'].state
    entities:
      - device_tracker.life360_name
    card:
      elements:
        - type: image
          image: "${vars[0]}"
          style:
            left: 50%
            top: 50%
            width: 50%
and even this:
    variables:
      - "'name'"
    entities:
    card:
      elements:
        - type: image
          image: >-
            ${states['sensor.' + vars[0] + '_picture'].state}
          style:
            left: 50%
            top: 50%
            width: 100%
took a while to find the correct (and rather unfamiliar) syntax intricacies of the template card …
normally a multiline notation dispenses with the outer quotes, but that doesnt work here, without using the white space cleaner >- and the double quoting of the variable string was new to me (btw you use triple single quotes, where using double quotes outside of inner single quotes is more default)
"'person1'"
since I believed the picture frame was an overlay, I now see t my surprise we have to fit the image exactly in to the center circle? That obviously requires more restraints to the images than I hoped for.
Could you please share the frame image and the size/resolution of the picture images needed for this setup?
thanks!
I think it is probably the Bitmoji app.
Sorry, just came back to this.
Here’s the frame with the transparent center. With my images I have them saved as png because I originally started that way, but there’s no transparency to them any more. However, I’m thinking you could first place the updating image and then over top of that image place the transparent frame (just make sure the frame is connected to the the same entity as the picture). This would give you the look your shooting for. Oh, and I’m using 500x500 pixel images with mine.
frame
Full control of the heating and radiator control, this was made family friendly. Top section was used using the button card and the lower section was with the picture elements card.
That’s beautiful, could you share your config please ?
