This is going into why I changed my setup, as I wanted to be able to use different themes and not worry about my tracker card being the wrong color.
Since the new frame is transparent it should work with any theme as long as your background is darker than your cards. The files in the ‘Michael’ and ‘Michelle’ folder are the same frame saved with each of the different location images so that as my tracker updates it places the appropriate image over top of the empty frame (thus you should never see it).
So, using a transparent image like this…
Produces this output without having any additional images being referenced depending on the theme…
Thanks! I do not, but I’ve had a few people ask so I feel like maybe I should get one going. Just haven’t been able to devote much time the past couple of months on HA. I’ll research how to set it up tonight…
My KISS approach after I found digital blueprints to our house. Things describe actual positions so no need to guess which movement sensor is running out of battery and always remove the wrong one first for example. Press and hold to toggle lights etc.
@bbrendon Just got it up a bit ago. Much more still to go. Not sure if there’s a good place to post updates… Using ‘Main Theme’ if you like the color layout.
how do you make the lights blend? Im trying to figure it out in the rooms where there are many source of lights how to manage the different combinations…
Just a little thing, but I wanted to fit my vacuum map and controls nicely on a phone screen and couldn’t find anything as compact as I wanted, so I made a very thin single-column picture elements card to fit nicely alongside my xiaomi map card.
