I found andrey’s customization https://github.com/andrey-git/home-assistant-custom-ui which allows to add several badges on a single line in a card.
That looks great, but now I want to accomplish something similar.
I also use the plant monitor https://www.home-assistant.io/components/plant/ and I really like how 5 sensor values are put this way on a single line. Seeing the icon is much easier than having to read the sensors name.
But how can I accomplish the same with 5 other sensors?
I guess I have to create a custom card? I really have no idea where to start…
Any help will be very appreciated
I thought I should explain myself a little bit more with some pictures, see below.
On (1) I’ve made a group of a climate object and several sensors.
On (2) I’ve used Andrey’s customization to show 5 of these sensors horizontally as badges.
But actually I don’t like those badges. I want something like on (3), similar to how the plant monitor shows 5 sensor values.
I used my paint skills for (3), but how can I make Home Assistant showing it like that?
