Here my experience: Plugged the “Lidl” gateway, installed Tuya Smart, choosed Gateway and it was done. Added a plug and a bulb in Tuya Smart using the “+Add” without any problem.
Added the Tuya Integration in Home Assistant and added the following to configuration.yaml:
Could you please explain, how you can extend the standard popup menu for a light? So, that you have the effects on top and the default on/off with color picker below.
I had the same issue not seeing all the devices I set up in my tuya account. In the meantime, I added some automation entries and was surprised to see them appear in HA. Now I know my account is working but something else doesn’t work right. I removed one of the devices and added it back then called tuya.force_update and tuya.pull_devices services without success. How is your progress?
I have noticed that my lidl bulbs and led strip shows as it is on even if it is actually off quite often. Anyone else have seen that? I am using deconz with HA
I find the Lidl bulbs can take over 3 minutes to show online (CC2531 running ZBM2MQTT) if someone switches off their power switch which is way too long compared to the Ikea bulbs that I have which take seconds.
I returned 1 Lidle RGBW bulb as it was buzzing when set to white and the other is back in its box as a spare.
They maybe cheap but the white Ikea bulbs are only a few £’s more and are much better IMO.
Anyone was able to run the colorloop effect on the Lidl LED light strip with deconz ?
so far it pair with Deconz very fast and I was able to change color with both deconz/home assisant, but colorloop effect is not working.
I binded as switch to activate the colorloop from Deconz, but it doesn’t affect anything on the light itself, I am only getting binary_sensor related to the color loop to set or unset, when triggering the switch
Yesterday my Lidl Gateway, some lights, motion sensors and door sensors arrived in the Netherlands. Everything is working fine in the Lidl app and also the Tuya app. unfortunately I’m also have problems to get the devices in Home Assistant. I prefer to have the gateway supported #voted, but if this is not possible or will take some (long) time I need to determine next steps. .
Be patient and hoping the Lidl Gateway will be supported/integrated by Home Assistant…
This means working with second app. and that is not why we have Home Assistant
Order Conbee II and trying to work with ZHA or deCONZ in a docker (My setup is in Synology NAS with a docker wit out supervisor)…
I prefer the vendor gateway for updates, support and fallback app when Home assistant is not working
Trying to get Tuya working…
Already tried everything I possibly could find like renaming devices without spaces and using other gateway in the Tuya app.and rebooting everything but devices won’t show up in HA.
If someone have some other options or things i can try let me know
I bought a Sonoff zigbee gateway ( 14 euros aliexpress) converted it to tasmota zigbee and all devices (bulbs, door sensor, PIR, remote) are working well,
I can pair the remote but not use it, have to dive deeper to get it working…
Convert, follow the ZHA option:
Here you can see which devices work with converted sonoff gateway.
