So would it go:
- alias: 'Lights On'
initial_state: on
platform: state
entity_id: binary_sensor.vision_zp3111_multisensor_4in1_sensor
to: 'on'
condition:
condition: and
conditions:
- condition: sun
after: sunset
- condition:
before: sunrise
- condition: time
after: '18:00:00'
before: '22:00:00'
- service: light.turn_on
entity_id: light.level_2
brightness_pct: 100
And does the rest of it look okay? Because for whatever reason this isn’t working.
Initial_state: ‘on’ - with quotes.
You still haven’t told us whether they actually are switched on?
Also, I don’t know where you are in the world, but I’m guessing that it’s never before sunrise AND between 6-10pm in the same day.
My guess is that the conditions you want are:
condition:
condition: or
conditions:
- condition:
before: sunrise
- condition: and
conditions:
- condition: sun
after: sunset
- condition: time
after: '18:00:00'
before: '22:00:00'
@anon43302295 thanks so much for your help. I’m obviously still getting the hang of how all the syntax works off of one another. This is what I currently have
- alias: 'Lights Off'
initial_state: 'on'
platform: state
to: 'off'
for:
hours: 0
minutes: 0
seconds: 30
service: lights.turn_off
initial_state: 'on'
platform: state
to: 'on'
condition:
condition: or
conditions:
- condition:
before: sunrise
- condition: and
conditions:
- condition: sun
after: sunset
- condition: time
after: '18:00:00'
before: '22:00:00'
brightness_pct: 100
- alias: 'Lights On Nighttime'
initial_state: 'on'
platform: state
to: 'on'
condition:
condition: or
conditions:
- condition:
before: sunrise
- condition: and
conditions:
- condition: sun
after: sunset
- condition: time
after: '18:00:00'
before: '22:00:00'
brightness_pct: 25
The goal is to get the lights to do those things only if the sun is down (e.g. I don’t want the lights going on on motion at 6pm if the sun is still up, like in the summer, but do want them going on at 6pm if the sun is down in the winter).
As I have it currently it says “invalid config” and i’m searching through it for the reason why. Also, if I can somehow buy you a beer let me know. I’ll send ya the money or something
In the first one, your service is lights.turn_off - should be light (no S).
What’s the actual error message?
It’s long, but this is the first part of it:
Testing configuration at /config
Failed config
automation:
- Invalid config for [automation]: extra keys not allowed @ data[‘condition’][0][‘conditions’][0][‘before’]. Got None
not a valid value for dictionary value @ data[‘condition’][0][‘conditions’][0][‘condition’]. Got None
required key not provided @ data[‘condition’][0][‘conditions’][0][‘entity_id’]. Got None. (See /config/configuration.yaml, line 98). Please check the docs at Automation - Home Assistant
- binary_sensor: [source /config/configuration.yaml:86]
sensors: [source /config/configuration.yaml:88]
hallway_motion: [source /config/configuration.yaml:89]
friendly_name: Hallway Motion
value_template: {%- if is_state(‘sensor.vision_zp3111_multisensor_4in1_burglar’, ‘8’) -%} true {%- else -%} false {%- endif -%}
Which line is 98?
Also your second and third automation have the same trigger, and the same conditions, with conflicting actions. Based on their titles that should be one automation with a data_template to set the brightness. What hours do you want the lower brightness between?
The lower brightness should be between 10pm and 7am.
As for line 98…I don’t have a line 98 in my automations. In my configuration, its group: !include groups.yaml
. So I’m not sure…
OK, you have an automation saved somewhere else that’s causing the error by the sound of that, maybe accidentally pasted something in your groups file?
Standby a sec and I’ll redo your lights on automation…
OK, get rid of the ‘lights on night’ automation completely, and replace the other one with…
initial_state: 'on'
platform: state
to: 'on'
condition:
condition: or
conditions:
- condition: sun
before: sunrise
- condition: and
conditions:
- condition: sun
after: sunset
- condition: time
after: '18:00:00'
before: '22:00:00'
data_template:
brightness_pct: >
{% if (now().hour >= 22) or (now().hour <7) %} 25
{% else %} 100 {% endif %}
initial_state: 'on'
platform: state
to: 'off'
for:
hours: 0
minutes: 0
seconds: 30
service: light.turn_off
initial_state: 'on'
platform: state
to: 'on'
condition:
condition: or
conditions:
- condition: sun
before: sunrise
- condition: and
conditions:
- condition: sun
after: sunset
- condition: time
after: '18:00:00'
before: '22:00:00'
data_template:
brightness_pct: >
{% if (now().hour >= 22) or (now().hour <=7) %} 25
This is what I have now. It passes the configuration test but the automation doesn’t seem to work when I walk past the motion detector. Any further thoughts?
I did restart it. And it is currently 10:00pm here.
Could it have to do with that I have a sensor template active? I’m not using it as my entity ID obviously, but I do have it in my config.yaml still.
Remove the line before: '22:00:00'
completely.
Also, I’m really sorry, but I got confused earlier, it should be initial_state: on
(without quotes).
Template sensor shouldn’t be affecting this.
Please, do not feel like you need to apologize. This has all been extremely helpful for me to learn how these things are worded correctly. I’m restarting it now, will let you know what happens.
Nothing. When I trigger both automations manually via the Front End they work appropriately, but the motion sensor does not activate them.
initial_state: on
platform: state
to: 'off'
for:
hours: 0
minutes: 0
seconds: 30
initial_state: on
platform: state
to: 'on'
condition:
condition: or
conditions:
- condition: sun
before: sunrise
- condition: and
conditions:
- condition: sun
after: sunset
- condition: time
after: '18:00:00'
data_template:
brightness_pct: >
I take it your sensor is showing as on in the states panel when you walk past it?
Yep, just double-checked.
And you’ve definitely copied the entity_id for it correctly?
And your time zone is correct? (so in your states panel sun is showing below horizon?)
