Hi.
I have done all your recommendations. The > does not change anything. The manual card I have added to the page shows “No card type found”. The editor adds ’ ’ to the mdi … and to the custom… lines but that does not change anything.
Keep in mind that I use picture element in some of the pages. I placed the new card in a regular page in which all cards are added from the menus and not manually edited to create the picture elements cards.
Ok, then please show your lovelae-code around the card.
Also, I am wondering, have the moment.js and is.js files been downloaded correctly? Some time ago I had the issue that I had thought a js-file had downloaded correctly but when I opened it in an editor I noticed all html-code so I had downloaded the code of the webpage instead.
Hi.
At 1st glance the is.js looks like a js file althought at the beginning the is a piece of something that does not look like a code. I will download it again to verify.
As for the lovalace card, I simply entered the ui edit, moved to the proper page and pressed the + icon and added a manual card with the content I have copied from here.
Hi again.
You are correct. The is.js file was messed up. I have fixed it. Anyway I have noticed the moments.js has to optional files: moments.js and moments with locale. Which one to use?
Anyway it is still in the same condition. It has an error.
Use moments.js, the other one doesn’t work, I tried it.
Can you show the code of your lovelace-card? The error must be in there somewhere.
Maybe I cannot help anymore as I’m using the ui-lovelace.yaml file.
Hi.
Should it be moment.js?
I use both. Some pages are yaml and some are regular card pages. I can move it to the yaml card. Will update and also re-check the tutorial for custom card.
Moment.js, correct
The js files are placed with the lovaelace raw editor. I do not use YAML (my mistake).
I have tried to put the card into the lovelace code and through the visual UI. Both do not recognise the card.
Please also check the contents of clock-card.js, maybe the content is malformed.
It looks OK.
Just upgraded to 107.0 and moved url: /local/JS/clock-card.js and url: /local/JS/moment.js to the new lovelace dashboards configuration but not working. the other items I had to move such as custom-cards are working. also replaced the clock-card.js to the most recent file, this was working for the last few months.
Hi. Something crossed my mind. I use compact-home so if this might cause the issue.
Sorry, I’m out of ideas how to help you.
Works like a charm. Is there an easy possibility to remove the seconds? I need some space and I prefer a more relaxed clock without chganging every second
Are you using my version?
If yes, I recently updated my version, removed all the moments-stuff.
Let me know, I’ll tell you how to remove the seconds.
Think so yes. I’m using this:
https://github.com/bouwew/clock-card/tree/patch-1
As suggested i did not use “moments–stuff”
Update: one correction made.
OK, great.
Open your local clock-card.js-file in an editor (I recommend the Visual Studio add-on).
Find this line:
this.time.innerHTML = hours + ":" + minutes + ":" + seconds;
Remove everything between the word “minutes” and the “;” at the end of the line and save the file.
Next, you must clear the browser-cache and reload the page. When using Google Chrome in Windows, press F12, right click on the browser reload button and select “Empty Cache and Hard-Reload”.
Now the seconds should be gone.
Works! Thank you very much for the impressive fast help
I’m having trouble getting the element to load. it keeps telling me moment is not defined. i’ve tried running this locally as well. any ideas?
Use my version of clock-card, it does not use moments.
See a few posts up, the post by Manuel82, for the link.
