Simple electricity meter manual input
You need to tell to your template sensor where it will read it’s value.
This is the state: part of the configuration, wich obviously is NOT in your configuration.
I would recommend to read : Template - Home Assistant
Then here is what’s missing from what I’ve understood of your setup :
template:
   - sensor:
      - name: energy_reading
        unit_of_measurement: kWh
        device_class: energy
        state: >-
          {{ states('sensor.energy_reading') | int(default=0) }}
But, if you set an initial value to your input_number it will go back to this value after every HA restart. You should not set the initial value, wich will lead to the input_number to get back the last value it has before HA restart.
