and as per this post
try this - it validates ok
display:
- platform: lcd_pcf8574
dimensions: 16x2
address: 0x27
lambda: |-
if (id(weed_fan).state = OFF) {it.print(8, 1, "F: OFF");}
else if (id(weed_fan).speed = '0') {it.print(8, 1, "F: LOW");}
else if (id(weed_fan).speed = '1') {it.print(8, 1, "F: MED");}
else {it.print(8, 1, "F: HIGH");}
it.printf(0, 0, "T:%.1f", id(weed_temperature).state);
it.printf(8, 0, "H:%.1f", id(weed_humidity).state);
it.printf(0, 1, "U:%.1f", id(weed_uptime).state);
Me neither, but YAML is pedantic, you had the correct state in your post you just changed it in your code
I changed that but it was still complaining, so I took your code and deleted out all the nested ifs (because its too easy to run into trouble with them) and ran with just one if/else.
It still complained so I got rid of your previous statements in the lambda and just ran with the one if so that I could get the validator to tell me where the error was, but that worked ok it didn’t complain about anything so I added the non if statements back in and that worked ok.
Then I googled “esphome nested if” and found that thread and added the nested ifs back in - let me know if it works for you.
