They do appear first time. I’m on a powerful system and a semi new phone though.
Mine’s not bad…
Hmmm… same system. What are you using for your DB?
Standard SQL Lite I’m afraid…
Could that make a difference?
Well that seems to be the difference between our setups. I use maria db on a separate server.
It just feels more like a frontend ‘issue’ to me.
Pressing F5 makes the lines disappear.
Simply navigating away to another tab and then back again makes them reappear.
I’m not losing too much sleep over this. It’s just a bit annoying…
Ok, so I just checked, and yes. I’m actually having the same issue. I was going off memory before. This must be new in .111
I’m still on .110
So i’m rejiggering the card. It has something to do with using the elements card to display the graph. I’m in the process of moving the card into the button card. Romrider fixed an update issue so we don’t need to use picture elements anymore. I’ll post the card when I’m done. Currently, it look’s like it’s loading instantly when all inside 1 card.
Ok, here it is. I renamed aspect to aspect_ratio to conform with the rest of my UI. You no longer need the transparent image either.
# lovelace_gen
{% set color = color|default('var(--paper-item-icon-active-color)') %}
{% set aspect_ratio = aspect_ratio|default('1/1') %}
type: custom:button-card
aspect_ratio: {{ aspect_ratio }}
entity: {{ entity }}
icon: {{ icon }}
color: var(--paper-item-icon-color)
show_name: true
show_label: true
show_icon: true
show_last_changed: true
tap_action:
action: more-info
haptic: light
styles:
icon:
- opacity: 0.3
- width: 100%
img_cell:
- top: 0%
- left: 30%
- position: absolute
- z-index: 2
grid:
- grid-template-areas: '"info info" "n n" "l l"'
- grid-template-columns: 40% 1fr
- grid-template-rows: 1fr min-content min-content
- position: relative
card:
- padding: 10px
- border-radius: 15px
- z-index: 0
name:
- justify-self: start
- align-self: end
- font-weight: bold
- font-family: Helvetica
- font-size: 12px
- text-align: start
- background-image: linear-gradient(to right, white 0%, white 80%, rgba(0,0,0,0))
- -webkit-background-clip: text
- -webkit-text-fill-color: transparent
- display: inline-block
- width: 100%
- align-content: start
- text-align: start
- text-overflow: unset
- z-index: 5
label:
- align-self: end
- font-weight: bold
- font-size: 12px
- text-align: start
- background-image: linear-gradient(to right, var(--paper-item-icon-color) 0%, var(--paper-item-icon-color) 80%, rgba(0,0,0,0))
- width: 100%
- text-align: start
- z-index: 5
custom_fields:
plot:
- top: 55%
- left: 50%
- width: calc(100% + 25px)
- transform: translate(-50%, calc(-50% + 10px))
- z-index: 3
- --paper-card-background-color: 'rgba(0, 0, 0, 0.0)'
- --ha-card-background: "rgba(0, 0, 0, 0.0)"
- --ha-card-box-shadow: 'none'
- pointer-events: none
info:
- align-self: start
- width: 40%
- z-index: 5
custom_fields:
plot:
card:
type: custom:mini-graph-card
entities:
- {{ entity }}
group: true
points_per_hour: 1
hour24: true
line_color: {{ color }}
line_width: 10
hours_to_show: 24
update_interval: 600
show:
icon: false
state: false
points: false
legend: false
average: false
extrema: false
labels: false
fill: false
labels_secondary: false
name_adaptive_color: false
icon_adaptive_color: false
info: >
var entity_id = (entity === undefined) ? 'Invalid Entity' : entity.entity_id;
var statestr = (entity === undefined || entity.state === undefined) ? null : entity.state;
var units = (statestr && entity.attributes.unit_of_measurement) ? entity.attributes.unit_of_measurement : null;
var date = (statestr && entity.attributes.device_class === 'timestamp') ? new Date(statestr) : null;
var value;
if (statestr && date === null) {
if (statestr.split('.').length - 1 <= 1){
var test = parseFloat(parseFloat(statestr).toFixed(2));
value = (isNaN(test)) ? null : test;
// test if units are in the state because some sensors are stupid. Looking
// at you synology.
const expr = /[^-.0-9]+/;
var has_units = expr.test(statestr.trim());
// console.log(`${entity_id}: "${statestr}" ${matches}`);
if (value && has_units)
units = statestr.replace(/[.0-9]+/, '');
// console.log(`${entity_id}: ${statestr}, ${units}, ${date}, ${value}`);
const length = 50;
const width = 3;
var radius = length / 2;
if (date){
let now = new Date();
var tdelta = Math.floor((now - date)/1000);
// console.log(`${entity_id}: ${tdelta}`);
function plural(descriptor, divisor){
var ret = Math.floor(tdelta/divisor);
return (ret == 1) ? [ret, descriptor] : [ret, `${descriptor}s`];
var values;
if (tdelta < 60)
values = plural('second', 1);
else if (tdelta < 60 * 60)
values = plural('minute', 60);
else if (tdelta < 60 * 60 * 24)
values = plural('hour', 60 * 60);
else if (tdelta < 7 * 60 * 60 * 24)
values = plural('day', 60 * 60 * 24);
else
values = plural('week', 7 * 60 * 60 * 24);
return `
<svg viewBox="0 0 50 50">
<circle cx="25" cy="25" r="${radius}" fill="{{ color }}" />
<text x="50%" y="43%" fill="var(--paper-card-background-color)" font-weight="bold" font-size="14" text-anchor="middle" alignment-baseline="middle">${values[0]}<tspan x="50%" dy="1.2em" font-size="10" font-weight="normal" >${values[1]}</tspan>
</text>
</svg>
else if (value && units && units === '%') {
radius = (length - 3) / 2;
const circumference = radius * 2 * Math.PI;
return `
<circle cx="25" cy="25" r="${radius}" fill="none" stroke="var(--paper-item-icon-color)" opacity="0.5" stroke-width="${width}" />
<circle style="
transform: rotate(-90deg);
transform-origin: 50% 50%;
stroke-dasharray: ${circumference};
stroke-dashoffset: ${circumference - value / 100 * circumference};
id="c_brightness" cx="25" cy="25" r="${radius}" stroke="var(--paper-item-icon-active-color)" stroke-width="${width}" fill="none" stroke-linecap="round" />
<text x="50%" y="54%" fill="var(--primary-text-color)" font-weight="bold" font-size="14" text-anchor="middle" alignment-baseline="middle">${value}<tspan font-size="10" font-weight="normal" >%</tspan>
</text>
</svg>
else if (value && units && units.includes('°')) {
return `
<text x="50%" y="54%" fill="var(--paper-card-background-color)" font-weight="bold" font-size="14" text-anchor="middle" alignment-baseline="middle">${value}<tspan font-size="10" font-weight="normal" >${units}</tspan>
</text>
</svg>
else if (value && units && units.length > 1) {
var y = (String(value).length > units.length) ? "50%" : "43%";
return `
<text x="50%" y="${y}" fill="var(--paper-card-background-color)" font-weight="bold" font-size="14" text-anchor="middle" alignment-baseline="middle">${value}<tspan x="50%" dy="1.2em" font-size="10" font-weight="normal" >${units}</tspan>
</text>
</svg>
else if (value) {
return `
</text>
</svg>
return `
<text x="50%" y="54%" fill="var(--paper-card-background-color)" font-weight="bold" font-size="14" text-anchor="middle" alignment-baseline="middle">${statestr}
</text>
</svg>
Nice…
Thanks.
FYI theres a visual History bug that will be fixed in .111.3. Might have caused the problems.
Except as I said, I’m on 110.
In any case your new implementation is a lot cleaner!
Right but I don’t know how far the history bug goes back. I can only state that it wasn’t in 110.3
