Single Sonoff ZBMini ghost switching, sort of (being turned on by light.turn_off)
i have found the solution to my problem. I have installed a rc snubber device. Now i can switch induktive loads like relays without any ghostswitching caused by backfire from the inductive coil. It was very esay to obtain one and simply connect it parallel to the coil of the relay.
Best regards.
Hi, I have same issue on my ZBMINI can you explain better your solution ? link to additional component to buy, picture of your assembly (if possible). Thanks
This is a rc snubber device
https://www.shelly.com/de/products/rc-snubber?srsltid=AfmBOoqP7knDqQlYUV42xyJejCghWud-A7VyeAXFfTv6_E34jblbW7o1
