Hey everyone! I have two motion sensors in the same room/group for my entryway - one at the top of the stairs, and one downstairs. What I want is to keep the three lights in the entryway group on as long as either detector senses movement.
I’ve only been able to trigger single sensors at a time - so the upstairs will detect movement, turn on the lights, I go downstairs, and then a minute later the upstairs sensor is no longer detecting movement, so it cuts the lights while I’m still downstairs. If I’m downstairs for more than five minutes, it’ll cut the lights too since I guess the timer starts as soon as it first detects an “off” state.
Any way to have either trigger reset the timer and keep the lights on if I’m moving around on either sensor?
Relevant triggers here:
- alias: "Entryway motion detected - upstairs"
platform: state
entity_id: binary_sensor.stairs_sensor_sensor
to: 'on'
service: script.turn_on
entity_id: script.entryway_motion_detected_script
- alias: "Entryway motion not detected for awhile - upstairs"
platform: state
to: 'off'
for:
minutes: 5
entity_id: script.entryway_motion_not_detected_script
- alias: "Entryway motion detected - downstairs"
platform: state
entity_id: binary_sensor.entryway_sensor_sensor
to: 'on'
- alias: "Entryway motion not detected for awhile - downstairs"
platform: state
to: 'off'
for:
minutes: 1
I would use something like the kitchen light timer. Use a script that turns off the light after a period of time but is reset when either motion is sensed by automation.
You mean this example? That’s what I’m using; however, the fact that the first of the two sensors no longer detecting movement turns off the lights even with the second sensor detecting is what is tripping me up.
I know this is pretty old and maybe resolved, but a solution to this could be using templating.
that way you can use a template that checks the state of one or the other or one and the other.
Have the automation use all binary sensors as the trigger, and then have templated conditions or templated actions.
