Sorry man, I realise I am plaguing you at this point… this reply is the first time I’ve seen any reference to mod_python? Are there instructions I’m not seeing beyond the following?
I have done all the above from root and I am a little further on now I guess. I am now able to see files on the server, I’ve created a test_script which I am able to view at http://localhost/cgi-bin/dhw_tank/test_script , but http://localhost/cgi-bin/dhw_tank/dhw_tank.cgi?temps=54.6,52.6,51.3,50.6,39.1,25.0&fmt=svg is still flagging an internal server error. Does this help point to anything obvious I am doing wrong?
Also noticing, I went down the instructions for the 8th time, and when i get to install python-svgwrite I get the following
root@pi:~# sudo apt-get install python-svgwrite
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
E: Unable to locate package python-svgwrite
right, bit more digging - i can finally see the image in my web browser. I had to run the following instead so maybe the instructions need updated?
sudo apt install python3-svgwrite
So, my final struggle. The markdown card… I believe I have it set up correctly, the local host has been redirected accordingly, the sensor names have been adjusted accordingly and the 2 additional have been removed - but no joy seeing a picture.
Just
Same thing happens even if i modify the image path to the test URL provided in the instructions (which is viewable in web browser). Any final words of advice?
I have a home assistant shortcut in chrome that opens it in a separate window - seems it’s what was blocking it appearing… So all is now working as intended! Thanks for all the help and patience bud, much appreciated!
I want this also on my home assistant. What did you do to get the script to run? I’m a beginner really with the Home assistant. Got a lot integrated so far with Tuya local / A/C units / Media players etc. But I couldn’t make heads or tails on how to run the python script Dave made.
as much as i got it working, im currently running down other avenues of making it suit my setup a little better.
I have it running on an apache server on another Pi - however because i am unlucky enough to not have a static IP at home, it’s only viewable in the house. I can’t check it out “visually” from work.
Maybe a little more info on what kind of setup you have and I may be able to help out a bit more?
I have used and modified Dave’s svg python script with trial and error for 10 hours, because we have 2 Tanks . Thanks for the great Idea and work on this . I would not be able to do this from scratch.
The Idea is what energy ( PV or Fernwärme ) is feeding the Speicher, and how much / long it was running. I have no idea how it will look on real data gg
This is the very first prototype without real sensor’s , just fake at the moment. I will use an ESP32 with 2x3 Sensors for the Tank, 1 Sensor to detect if fernwärme is on and a PAC2200 to get accurate KW from both Heizstab .
Well done on this. I have since learned about how to create a custom card in HA. That will be way easier way for a user to use this (no web server or mod_python required).
